Transmission very slow to go on cold mornings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ryanr317, Jan 10, 2017.
  1. Jan 10, 2017 at 5:53 AM
    Ryanr317
    Ryanr317 [OP] New Member
    2001 Tacoma Prerunner
    Hey all,
    My 2001 PreRunner V6 has been acting weird the past few cold mornings. And by cold, I mean 50s since I'm in FL. The transmission seems to slip when the truck is started in the morning after sitting overnight. At first, you've got to rev her up to about 3k rpm just to get moving. After a 1/4 mile or so, it starts to feel more normal. This is not the normal holding of 1st and 2nd to get the engine warmed up faster. However, on a morning that's in the 60s or above, it's fine.
    I've done 3 drain a fills with synthetic Dexron II as indicated by the drain plug and manual. The fluid seemed very clean to begin with. I have not changed the filter. The fluid level also looks to be right.
    Any ideas on what could be causing this?
  2. Jan 10, 2017 at 5:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Mileage?
    Were the fluid changes done regularly, or were your 3 changes part of a cleanup / catchup effort?
    Your description is classic of sticking valve body, worn clutch packs, low fluid levels, or a combination of all 3.
    Since your changes should have addressed 1 & 3................ for your sake, hope I'm wrong.
    Maybe @gearcruncher can give more thoughts.
  3. Jan 10, 2017 at 6:03 AM
    Ryanr317
    Mileage just turned 140k. I just got the truck last August and I'm not sure how frequently the transmission was serviced in the past. I went ahead and did the fluid change after noticing the symptoms.
  4. Jan 10, 2017 at 6:15 AM
    Tim7902
    Tim7902 Well-Known Member
    Tim
    Maryville, TN
    2001 tacoma doublecab
    Try charging your battery, or replacing it. I had this same problem a year or so ago and it ended up being my battery voltage was low causing the solenoids in the transmission to not get the correct voltage when first started. After driving for a few minutes it would quit happening. I'm guessing the alternator would charge the battery enough so the solenoids would get the correct amount of voltage.
  5. Jan 10, 2017 at 6:25 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Check your fluid level warm, make sure it reads same both sides of stick. Then in the morning, a cold one preferably before starting engine pull the dipstick and check. If the fluid level is way high by inch or so you have converter drain back which is somewhat normal to a point. If this is case what is happening is converter is not full when you put in gear giving you feeling of neutral until it fills. If fluid in morning is low when checking which I doubt like below add then your just plain low on fluid which can cause similiar problem. This is just another thing to check out also.
  6. Jan 10, 2017 at 6:32 AM
    sawed off
    Randy
    Idaho
    I also would not be afraid to throw in one extra quart and see if that changes anything, when first starting out in morning front pump has to fill converter, cooler, and fill clutch paks, if your a little low pump will starve until warmed up.
  7. Jan 10, 2017 at 6:59 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Let your truck warm up a little before rolling down the road. All the fluids need to reach proper viscosity. I NEVER just jump in, start the engine and put the transmission gear.
    I compare it to someone dragging you out of bed, jumping on your back, and expecting you to take off in a full sprint properly.
  8. Jan 10, 2017 at 12:31 PM
    Ryanr317
    I get this, except i'm just trying to get it out of the drive way. Either way, something's got to be off if it takes 3k rpm just to move. All good suggestions I'll have to look into. The Battery one is interesting.
  9. Jan 10, 2017 at 2:38 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    honestly this is the same thing that happens here in sub 30* temps.
    the fluid has to warm for it to flow better. drive slower to start off and don't let the truck idle for more than 30 seconds, you're just wearing out other parts. it'll warm up faster once you are moving.
    how does the fluid look? pink, red, or dark cherry? worst case you can always drop the pan and replace the filter if you don't know the mechanical history. nor do you know if the previous owner beat the s*&t out of it.
    edit: the sensors in the trans will prevent it from shifting until it has warmed to a certain temp, don't gun it or rev it too high
  10. Jan 10, 2017 at 6:28 PM
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    Everything's fine, mine started doing this at 25 and below. Fluids are perfect. Just cold mate...
  11. Jan 11, 2017 at 4:44 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Are you checking the fluid level with the engine running after putting shifter through all gears and back to P?
    gearcruncher likes this.
  12. Jan 11, 2017 at 8:56 AM
    gearcruncher
    Canadain bumper technician
    I would be interested to know if the engine is running when checking the fluid as well ?
    If you are checking the fluid with the engine turned off the fluid level will show far over the full mark because none of the hydraulic circuits are charged
    Here are some diagnostic links for the OP to research http://etereman.com/blog/transmission-care/common-problems-found-in-the-toyota-a340e-transmission
    http://www.sonnax.com/parts/2764-zip-kit
    https://www.tacomaworld.com/threads...sions-write-up-your-4-speed-automatic.325531/
