Transmission went out :( need help finding another
Discussion in 'Technical Chat' started by 1999tacotrd, May 13, 2009.
  1. May 13, 2009 at 10:14 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Hi my transmision went out over the weekend and i need to find another somewhere. my truck is a 1999 taco trd 4wd 3.4l 6cly and what i need to know is what transmissions can i use like will 4runners work or prerunners and also what year models ? i found one on ebay for a 2002 prerunner 3.4l 6cly and it says it would work on a 4wd if i swap out the rear of the transmission can any one comfrim this? if not dose any one know of a good online slavage that deals with toyotas? thanks in advance
  2. May 13, 2009 at 10:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You have an A340F tranny....find one from a 4x4 if you can as the tail of the tranny is different, and Im not sure it can be swapped out.
  3. May 13, 2009 at 10:20 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    when a guy i know was going thru his prerunner-4x4 swap...he started out planning on using his prerunner tranny...but it was going to be a MAJOR PITA to change the tranny over to a 4wd version...
    find a 4x4 tranny and save yourself the headaches
  4. May 13, 2009 at 10:20 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    its not worth the hassle, try to find one out of a 4x4, did u check craigslist?
  5. May 13, 2009 at 10:44 PM
    1999tacotrd
    yeah i checked crigslist it has crap around here for tacoma parts. I will call some salvage yards as well as check ebay for a 4x4 one
    also what year models should i look for on a 4x4 one?
  6. May 13, 2009 at 10:49 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    A340F
    i think all v6 tacomas from 1995.5-04 had them
  7. May 14, 2009 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All the 4x4's had the "F".....Prerunners had the "E"
