Transmission- what numbers tell me what transmission is needed for replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dogman88, Nov 26, 2024.
  1. Nov 26, 2024 at 6:45 PM
    Dogman88
    Dogman88 [OP] New Member
    04 sr5 trd 4dr v6 4wd auto black 300,000 +
    Have been to a couple yards and cannot get straight answer on what transmission I need to replace mine.All I have is a340f
  2. Nov 26, 2024 at 8:20 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  3. Dec 9, 2024 at 7:07 AM
    Dogman88
    Thanks, I found a transmission! Now I need info on the swap, tools needed, lift and or trans lift, would like to do it myself, have heated garage, do not have a ton of knowledge so advice and step by step is what I seek.Thanks.
  4. Dec 9, 2024 at 8:21 AM
    CA-Taco
    CA-Taco Well-Known Member
    Santa Cruz Mountainss
    1999 PreRunner TRD
    1999 PreRunner TRD 5VZ 3.4 V6 AutoTrans 4x4 Swap ADS Coilovers w/adjusters New OEM Bushing UCA and LCA @210k Mi Stock LCA, SPC UCA REH5108 Coilbucket Gussets Total Chaos Spindle Gusset DuroBump Front Bump Stop Alcan Springs +800 lbs +2" ADS w/adjusters Rear Shocks U-Bolt Flip-Durobump DuroBump 4.25” Bump Stops Custom Shock Relocation 4.88 Yukon Gears Eaton Front Locker SCS Ray10 16x8 Bronze 255/85R16 Cooper Discoverer S/T Maxx Dakota Digital SGI-100BT Speedometer Interface Stock Front Bumper with Custom Hidden Winch Warn M8 w/Synthetic Rope w/Factor55 Flatlink E Nguyen Works Bumper w/Dual Swing Outs (Greasable KP Off-road LCA Bolts for Swing Out Bearings) BAMF Sliders 4x Innovations Front and Transmission Skid Plates Dometic CFX 55im Fridge/Freezer Big 4 wiring Mod Singer 128.5MM Denso hairpin style (6 phase) 180 A (200 A Max, 150 A Idle) X2Power AGM Group 35 Battery Renogy Deep Cycle AGM 12 Volt 100Ah Battery Renogy 20A DC to DC Battery Charger Victron Energy SmartShunt 500 amp Battery Monitor BlueSea Bus Bar on Custom Engine Bay Mount Victron Energy SmartSolar MPPT 20 amp Solar Charge Controller Renogy 100 Watt Eclipse Foldable Solar Panel Osram Super Bright 100/90w 2900 lumen H4s Headlight Services Harness 13WL Brake Calipers Braided Steel Brake Lines OBDLink MX+ OBD2 Bluetooth Scanner & OBD Fusion App Kenwood DMX958XR Soundproofed Cab - Dynamat and Second Skin Wet Okole Seat Covers Rebuilt Engine when Head Gasket Failed (215k Mi) Hayden 699 Transmission Cooler (Replaced B&M 70264 Cooler) Magnetic Inline Transmission/Power Steering Filter 4 x 4 Conversion w/Yota1 Rebuilt AT, ECGS Rebuilt Front Diff, '99 Taco TC, Manual Hubs GFC Camper V2 LSPV Delete Funky Home Made Mud Flaps and Hangars (1/4” Conveyor Belt Material; 12” x 18”)
