Transmission whine/drone
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lmikk12, Feb 20, 2012.
  1. Feb 20, 2012 at 4:14 PM
    lmikk12
    lmikk12 [OP] Active Member
    Big Bear, CA
    12 Tacoma 5 Lug
    I recently bought a new tacoma 2.7L 5 spd and when i am in 4th gear and around 2k rpm i get a small whine but it doesn't do it in any other gear, anybody else experience this?
    thanks
  2. Feb 20, 2012 at 4:15 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    whine or spun bearing sound?
  3. Feb 20, 2012 at 4:22 PM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    Just a small whine and it goes away at about 2200 rpm, maybe im lugging it too much?
  4. Feb 20, 2012 at 4:23 PM
    08pretaco
    Oliver
    az
    cant think of anything else it might be. change the shift points and see what happens.
    I have a spun bearing sounds in 5th at a certain speed range
  5. Feb 20, 2012 at 4:27 PM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    Ya if i keep the revs a little higher it doesnt do it and i only have 1000 miles on it so i would hope it isnt a spun bearing. thanks for the insight.
  6. Feb 20, 2012 at 4:59 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    4th gear is direct (1:1) meaning it is locked straight through so the trans will not make noise in 4th my guess is a slight rear end whine. You are more likely to hear it in 4th because nothing else in the trans is doing any thing. I don't think I would worry about it turn the radio up a bit.
  7. Feb 20, 2012 at 5:04 PM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    haha thanks, i know that all types of gearboxes make a little noise(4x4 ranger is awful) but if it is the rear end is that normal or should i change fluid or anything?
  8. Feb 21, 2012 at 4:32 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    As new as it is it might be a good ideal to let the dealer have a look if nothing else it establishes a time line in case you do end up with a problem in the future it's probably nothing but a good part of what you paid for the truck covers warranty so you might as well use it.
  9. Feb 21, 2012 at 3:32 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I've never heard a manual tranny not whine in a gear until I got my taco.
    The 2.7L I test drove before my current truck whined a little. Both my previous Hondas whined pretty good in 4th.
    Easier to hear when you're sitting next to the tranny instead of behind it like in a car, although it seems to be quieter in the Toyotas because they use 75w90 instead of Honda MTF (I don't know if it's thick enough to qualify for 70w80, the new formulation is ATF thin). The heavy gear oil really sucks up some vibration.
    I'd ask the dealer to test drive a couple 5 spd 2.7s myself to verify if it's something common to all the R155 trannies.
    It's possible the gears are whining when the countershaft is unloaded in 4th gear and any tolerances normally taken up by engine torque are loose again.
  10. Feb 21, 2012 at 4:14 PM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    thats a good idea, and if they dont whiine then i am already at the dealership haha thanks for the input
  11. Feb 21, 2012 at 5:31 PM
    jpaw30
    jpaw30 Well-Known Member
    at 50mph the differential will whine, there's a tsb about it
  12. Feb 21, 2012 at 9:49 PM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    awesome thanks
