Transmission Whine PLEASE HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Asta, Feb 5, 2012.
  1. Feb 5, 2012 at 7:08 PM
    Asta
    Asta [OP] Hold My Beer and Watch This
    Daniel
    Kings Bay, Ga
    2014 DCSB Tacoma TRD OFF-ROAD
    I was looking at a Taco and I like everything about it except the Transmission is noisy. Manual trans that whines in most gears. 4th is quite but the others make a whining noise. Owner has owned truck from 32,000 miles and says it has done it the entire time he has owned it. He has had it checked and technician said it may run forever making noise and not breakdown, Truck now has 157,000 miles.
  2. Feb 5, 2012 at 7:20 PM
    Phearson
    Phearson Taco or Die
    Brad
    Gresham OR
    1996 SR5 Tacoma. 33x10.5 Kevlar 3in lift
    Its prob a THROWOUT BEARING. My buddys Ranger makes it in low to mid RPM's. But were not Rangers thank god... But if its coming from the tranny. Probably a bearing
  3. Feb 5, 2012 at 7:24 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Mine is the same, its not the throw out bearing, that only makes noise when the clutch is pressed in.
    It is the input shaft bearing deep within the transmission, leave it alone unless you want to rebuild the trans.
  4. Feb 5, 2012 at 7:39 PM
    Asta
    Daniel
    Kings Bay, Ga
    ya its only when its pressed thanks man!
  5. Mar 17, 2012 at 11:03 PM
    RT831
    RT831 Member
    Santa Cruz
    White 4x4 SR5
    did you ever figure out what was wrong with it?
    or have it checked out?
  6. Jul 10, 2012 at 8:06 AM
    JPazEco
    JPazEco New Member
    Jean-Paul
    I've got the same issue on a 2003 Taco I just purchased recently. This isn't something that's going to cause more issues down the line? I'm getting ready to drive it across the country and I don't want it to leave me stranded in the middle of the desert.
    Thanks,
  7. Jul 10, 2012 at 8:20 AM
    Critta93
    Critta93 Well-Known Member
    Virginia
    2000 Toyota Tacoma SR5 TRD Offroad V6
    3" coil over suspension lift and 3" body lift on 35's.
    Toyota is famous for a transmission whine, all years up until 2nd gen. Leave it alone.
  8. Jul 11, 2012 at 4:12 PM
    Asta
    Daniel
    Kings Bay, Ga
    Its the input shaft bearing i had a guy that was the head mechanic at toyota take a look at it he said it will be fine i plan on replacing mine when i have to get a new clutch i just do the turn the radio up mod and you dont notice it
  9. Jul 12, 2012 at 7:36 AM
    Critta93
    Virginia
    Yeah that's a nifty mod. Seems to work on several occasions haha
  10. Jul 13, 2012 at 10:00 AM
    JPazEco
    JPazEco New Member
    Jean-Paul
    Sweet, I've gotten the same response from multiple people. I'll let it run its course then and change it out when its time to replace the clutch. Thanks!
