Transmission whine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phxsunbum, Apr 30, 2012.
  1. Apr 30, 2012 at 10:33 AM
    phxsunbum
    phxsunbum [OP] New Member
    Robert
    Phoenix, AZ
    2007 PreRunner SR6 Double Cab
    I have a 2007 Tacoma PreRunner Double Cab, 5speed Auto Tranny, with 95,000 miles one it. Last week it started to whine, very similar to the transmission sound you hear when you go at a higher rate of speed in reverse. When you slow down the whine continues (just like when reversing and you let off the gas) but slows to match the engine, same with acceleration.
    Any thoughts?
    Thanks!
  2. Apr 30, 2012 at 12:19 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Check the diff before assuming its the tranny. Does the noise change noticably when the tranny shifts? Or simply with speed no matter what gear the tranny is in?
  3. May 1, 2012 at 6:26 AM
    phxsunbum
    Robert
    Phoenix, AZ
    I've had the truck serviced every 5k miles at Toyota since I bought it. The noise remains constant regardless of what gear the tranny is in. However, when I shift into neutral the noise stops.
  4. May 1, 2012 at 7:34 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    In that case, it does sound more like the diff.
  5. May 1, 2012 at 11:19 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Could also be a pulley.
  6. May 2, 2012 at 7:42 AM
    phxsunbum
    Robert
    Phoenix, AZ
    Thanks for your good advise everyone. Turned out it was the differential. Rather than pay the $2400 to have it repaired, plus it's time to do the brakes and replace the tires, I opted to trade it for a 2012 Tacoma Double Cab Pre Runner.
    My fiance thinks it was so strange that I go to the dealer and come home with the exact same truck, only a 2012 instead of a 2007. Same color, trim pkg, etc.
    Oh well, what can I say? You can't mess with a good thing!
    Thank again folks.
  7. May 2, 2012 at 7:51 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Very nice, decision!
  8. May 2, 2012 at 7:59 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Smart decision.If you would have put $2400 in repairs plus $600 to $800 in tires plus brakes you would have at least $3000more in your truck and it would not be worth a dime more.
  9. May 2, 2012 at 8:09 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    just curious...how did you make out as far as trade-in value on your 07?
  10. May 3, 2012 at 8:05 AM
    phxsunbum
    Robert
    Phoenix, AZ
    Actually I did pretty good. The KBB for "Excellent" was $15,535, but since it required the work they gave me $13,500. I was happy with the deal, especially since I only had to finance about $15,000 which kept the payments low for 4 years.
  11. Feb 3, 2013 at 8:18 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Shit. I think I have this problem...
    $2400, that sucks.
