Transmission With No fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by JosiahMask14, Mar 28, 2025.
  1. Mar 28, 2025 at 2:48 PM
    JosiahMask14
    JosiahMask14 [OP] Member
    1998 Tacoma 2wd 2rz Standard cab
    Hey there,
    So I have been working on my truck over my spring break. I am replacing the clutch and rear main seal and all the rubber mounts. But at the start of this project I noticed there was a big leak where the transmission and the drive line meet. I own a 2wd 2rz w59. Then I went to drain the transmission fluid and roughly 1 cup of fluid came out... That explains why I have been having problem with my transmission.
    I am just wondering what I would need to fix this. Is there a name for the seal I need? Will I need to disassemble the transmission?
    Thank You
