Transmission would not engage in Drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JqC, Jan 24, 2021.
  1. Jan 24, 2021 at 9:26 AM
    JqC
    JqC [OP] Member
    2005 Tacoma TRD Sport DCLB
    My 2005 Tacoma has 183k miles. It was parked in our driveway, uninsured for the last 3 months.
    This morning I decided to start her up. The engine started up fine, but after I shifted to Drive, the truck wouldn't move.
    The engine would rev as if it were in neutral.
    Over the next few minutes I tried shifting between park and drive. Eventually, the I heard a loud 'thunk' when I was in Drive and gave it more gas. After that, the transmission seemed engaged and the truck was able to drive normally.
    I drove the truck around the neighborhood and tested park, reverse, drive, etc. All behaved perfectly fine, albeit a bit rough from age.
    Has anyone encountered something like this before? If so, what was the diagnosis? Did you find a solution?
    I'm wondering if this is a sign of major transmission problems.
  2. Jan 24, 2021 at 9:52 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Jimmyh likes this.
  3. Jan 24, 2021 at 10:03 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Not sure where you live but cold temperature combined with a lack of use could be to blame. I’d definitely start by checking the fluid level and then go from there as stated above.
  4. Jan 24, 2021 at 10:26 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    After sitting for long periods fluid can drain away from valve body causing sticky valves (mentioned above) and delayed engagement.
    Like others said
    changing fluid sure wouldn't hurt
