transmission
Discussion in 'Performance and Tuning' started by beastlytaco, Jul 1, 2008.
  1. Jul 1, 2008 at 7:24 PM
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    okay in the 4 cyl you have the automatic transmisson. a buddy of mine said you can manually shift through the gears like 1 to 2 to 3 and to 4 but cant that really screw up ur tranny
  2. Jul 1, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nope. :) I shift mine manually all the time when driveing thru hills or off roading.
  3. Jul 1, 2008 at 7:29 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    You can "cowboy" the gears but you have to use good judgement with RPM's. Dont redline, dont wind up the RPM's real high then drop the gas in the same gear, dont downshift too soon...stuff like that. Just dont be abusive.:)
  4. Jul 1, 2008 at 7:34 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    say i was racing some guy in a corolla could i do it then
  5. Jul 1, 2008 at 7:37 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Do you have the "ECT" button on the dash in that '08? Anyway if youre racing a corolla just leave it in drive. Youll do fine:D
  6. Jul 1, 2008 at 7:53 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    oh yeah 4x2 and 2x4 are the same thing right?
  7. Jul 1, 2008 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One is a truck drive lay out, the other is wood. :D
  8. Jul 1, 2008 at 8:36 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    2.7 4x4 is a 5sp manual transmission
  9. Jul 2, 2008 at 10:35 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    HOLY SHIT i laughed so loud when i read that :rofl:
  10. Jul 2, 2008 at 10:54 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    :laugh:
    as to the original question, you probably won't damage it immediately, but if you make a habit of it, expect your engine and transmission to wear out quicker. Consistently operating at higher RPMs is pointless. If you have too much gas, feel free to send some to me.
  11. Jul 2, 2008 at 10:56 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    OMG.... That was funny man! :D:D
  12. Jul 2, 2008 at 10:56 AM
    eordonez
    Ed
    Chihuahua, Mexico
    +1
  13. Sep 10, 2010 at 5:38 PM
    milo39
    milo39 Well-Known Member
    myles
    downey,ca
    07 doublecab prerunner trd off road
    i got a 2007 prerunner its automatic 2wd. what gear would i put it in when off roading?
  14. Sep 24, 2010 at 10:17 AM
    scott20054
    scott20054 Active Member
    tuned TRD supercharged taco
    TRD Supercharger, IPT High Performance Transmission, DTLT long headers, APR X-1 tuner, Full fiberglass body, E85 injectors, APR 7th injector, Walbro 255 fuel pump, Pulstar Performance Series Spark Plugs, 2.7" pulley, Flexalite Electric Cooling Fan, Cooler Thermostat System, Timing gears, Pro Comp Traction Bars, K&N Cold Air Intake, Airaid PowerAid Throttle Body Spacer, Aero Turbine 2525 with custom piping true duals, Grillcraft MX Series upper and lower grill, Redline Tuning Hood QuickLIFT ELITE, 20% tint front, 5% tint back, tinted headlights, tail lights, fog lights, and mirrors, Debadged, ... So YES this truck is "STOCK" ;D
    it works great for towing, off road, and racing. like i use it when i race so if i take some gas off it wont up shift and then slam gears when put more gas to it. but just normal driving around keep it in drive but for going out having fun o yeah use it!!! :D
