Transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by Redwood, Dec 26, 2016.
  1. Dec 26, 2016 at 6:30 PM
    Redwood
    Redwood [OP] Member
    2004 tacoma
    New moter trans
    I have a 04 tacoma was wondering if anyone knows how i can get higher gearing in 1st and 2nd gear or if i can swap out the trans to something qith higher gears any info or advice is much appreciated
  2. Jan 6, 2017 at 11:38 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Do you mean taller gears with more teeth ? If you go taller gearing you'll be lugging the engine when starting out...especially on hills.
    What is your goal ?
  3. Jan 6, 2017 at 11:52 AM
    Redwood
    Redwood [OP] Member
    2004 tacoma
    New moter trans
    My goal is to get my truck moving faster in first and second gear or more power to the wheels thank you for your time
  4. Jan 6, 2017 at 11:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    That gets fairly complex and expensive, even if there is an option to do so.
    It's much easier (albeit may still not be cheap) to swap the rear gearset for a higher numeric gear.
    Do you have some kind of jumbo rubber on the truck? That results in an effective gear lowering.
  5. Jan 6, 2017 at 12:14 PM
    Redwood
    Redwood [OP] Member
    2004 tacoma
    New moter trans
    It's completely stock two wheel drive with stock wheels and tires truck runs amazing first gear just seems really low to me but then again im new to owning a toyota
  6. Jan 6, 2017 at 12:21 PM
    cruisedon66
    Pete
    Near St. Louis
    Maybe an extra set of smaller wheels to put on for racing ? Keep the stock wheels for economy.
