Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Matthew501, Feb 4, 2023.
  1. Feb 4, 2023 at 12:36 PM
    Matthew501
    Matthew501 [OP] New Member
    Matt hoskins
    2017 Tacoma SR
    Anyone have any say on why my 2017 SR 4 banger. Shifts decent in the flat but shifts like trash up hills, seems to rev pretty high into 4th sometimes doesn't shift out even after reaching the top and starting back down the other side.
  2. Feb 4, 2023 at 12:39 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Just the way it is with the 2tr-fe. Especially in any sort of elevation.
    Junkhead likes this.
  3. Feb 4, 2023 at 12:42 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    that's ideal, you don't want to be in overdrive when climbing a hill. there's not enough torque.
  4. Feb 4, 2023 at 12:58 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Heavy truck, lot's of wind resistance, small engine, transmission logic and gearing to make GOV happy (not the driver)= sounds right
    welcome
    not being snarky, but if you don't like the way it drives, why did you buy it?
  5. Feb 4, 2023 at 1:25 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds exactly like the test drive I did in a 2020 sr 2.7 auto.....totally gutless. I ended up with the 3.5.
    Junkhead and shakerhood like this.
  6. Feb 4, 2023 at 1:35 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    Normal, even the v6 do this.
  7. Feb 4, 2023 at 1:49 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    When you start up a hill, and before the engine starts to strain, manually downshift to 4th gear and leave it there. You may even have to go to 3rd or 2nd depending on how steep the hill and how heavy you're loaded. You and the truck will be happier. And when come down the other side leave it in 4th, 3rd, or 2nd gear to let the transmission slow you and stay off the brakes as much as possible. Just because it is an automatic doesn't mean you aren't in control.
    LeakyAC likes this.
  8. Feb 4, 2023 at 2:53 PM
    The_vue's
    The_vue's Well-Known Member
    18 cement
    Let me guess it stumbles too?
  9. Feb 4, 2023 at 3:40 PM
    LeakyAC
    That's more a 3.5L v6 thing I think
  10. Feb 4, 2023 at 7:56 PM
    Kidlin
    Kidlin Well-Known Member
    2021 SR5 DCSB Cement
    I had a 2.7 08 Tacoma before I got my 21’ 3.5L. My experience on both is you just have get into them and lay into the skinny pedal sometimes. When it comes to hills I would say more so on the 2.7. I really had to force it to shift and make all its power on long mountain passes. Getting a running start helps a lot too. My experience of the 3.5L is that it performs a lot better and really doesn’t seem to mind the higher revs. I personally think driving it a little hard the first 10k miles (after the break in period) helped the transmission programming learn to shift when I tell it to. It doesn’t hesitate to get up and go at all anymore. I like both engines and actually preferred the 2.7 for most types of daily driving.
  11. Feb 4, 2023 at 8:08 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    You have two over drives on this transmission, 5th & 6th and you’re trying to go uphill, with a 4 cyl, what else can be expected?
    Use ECT, and S-4 and your situation should improve.
    Junkhead and Chew like this.
  12. Feb 5, 2023 at 6:25 AM
    zoo truck
    None
    Not mine.
  13. Feb 5, 2023 at 6:33 AM
    zoo truck
    None
    When I push the skinny petal down some on my 3.5 it responds instantly...no hesitation. I've never seen much over 3k rpm even on long hills. It will hold 60 mph up that hill under 3k rpm like nothing. These 3.5's are no slouch if you got one that performs well, and from what I've seen, and now heard some run great, others not so much.
  14. Feb 5, 2023 at 12:44 PM
    Brucey
    Bruce
    Ovtuned
    So if you were going up a steep high at 60mph your truck would not down shift and keep you at 6th gear while keeping you60mph
  15. Feb 5, 2023 at 12:49 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Same, never had a “stumble”
