Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kgbrev, Apr 23, 2025.
  1. Apr 23, 2025 at 10:41 AM
    Kgbrev
    Kgbrev [OP] Well-Known Member
    2020trdoffroad
    Diamondback SD cover
    Does anyone know if you can buy new tranmission for a 3rd gen tacoma?
    HondaGM likes this.
  2. Apr 23, 2025 at 10:42 AM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Is it Friday ?
    kahanabob and HondaGM like this.
  3. Apr 23, 2025 at 10:43 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Im sure Toyota will sell you one..
    shakerhood likes this.
  4. Apr 23, 2025 at 10:54 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Can you explain in more detail why you feel you need a new transmission in your 2020?
    Also, have you checked or changed the transmission fluid?
    Greg-tacoma, kahanabob and HondaGM like this.
  5. May 1, 2025 at 12:54 AM
    Kgbrev
    2020trdoffroad
    It's fine, I just read that toyota doesn't sell replacement transmissions. And I was curious if anyone knew anywhere that does.
  6. May 1, 2025 at 4:01 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    The google tells me there are plenty for sale :evil:
  7. May 1, 2025 at 4:45 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    If Toyota won't (I'd be surprised), Jasper will.
  8. May 1, 2025 at 6:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    May we ask the source of this reading?
    You Tube? Social media? Other?
  9. May 1, 2025 at 6:47 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I don't think you can order a "new" transmission for a 3rd gen anymore. You can order a reman from Toyota though and they aren't too terribly expensive. 35010-04120-84
  10. May 1, 2025 at 7:18 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    After xxxx miles, if you have a failure, engine, trans, etc, toyota doesnt drop in a new one for you, its a reman....
  11. May 1, 2025 at 8:09 AM
    Horseshoez
    Dale
    Maryland
    By definition, a "remanufactured" transmission (or any other component) is as good, and often better, than the OEM unit. This is not to be confused with a "rebuild" where the parts are only replaced if they are out of tolerance.
  12. May 1, 2025 at 8:21 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, why not call your local dealers parts department?
  13. May 1, 2025 at 8:30 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Not yet.
