transmisson cooler trd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Feb 22, 2009.
  1. Feb 22, 2009 at 8:38 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    What would be the pro's of having the auto trans cooler installed on my supercharged 02 taco?
  2. Feb 22, 2009 at 8:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It will keep your tranny cooler, thus prolonging its lifespan.
  3. Feb 22, 2009 at 8:42 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep........what 4x4 said....................but honestly, you can go get a b&m tranny cooler from autozone for alot cheaper than the trd one.......and they are relatively the same. they wanted $300 something for the trd one at the dealership.......and i can get a b&m one for around $50 at autozone or oreilly's. just a heads up.
  4. Feb 22, 2009 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Also, as you are supercharged, you might want to look into the Level Ten valve body upgrade.
  5. Feb 22, 2009 at 8:56 AM
    4421.frank
    Southside chicago
    Level Ten valve body upgrade., whats that?
  6. Feb 22, 2009 at 8:59 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    heavier duty valve body for you transmission that the stock valve body.
  7. Feb 22, 2009 at 9:02 AM
    4421.frank
    Southside chicago
    what does that do performance wise?
  8. Feb 22, 2009 at 9:04 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  9. Feb 23, 2009 at 6:09 PM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    I was told by a guy from a tranny shop to get a cooler and bypass the cooler in the Radiator. Apparently, the original cooler can rot out and put coolant in the transmission, you wouldnt see it until it is too late. He said it was common in Toyota's.
    I bought my cooler on Amazon for $50, the same one in the TRD kit without the $250 worth of brackets, and ran hard lines through the radiator support.
    I did a fluid change about 3 weeks ago, 30k and everything looked good.
  10. Feb 23, 2009 at 6:26 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    hardlines...excellent idea. I've wanted to put a cooler on mine for a while but was always a tad worried about the hoses.
  11. Feb 23, 2009 at 6:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have NEVER heard of that happening on a Toyota. The chances of the cooler lines rotting out in the raiator are very slim.
  12. Feb 23, 2009 at 6:52 PM
    HerNameIsLucy
    RIP Lucy.
    In New England they use so much salt on the roads I'd worry about the radiator rotting away from the OUTSIDE first!
  13. Feb 23, 2009 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    x2. And considering most modern radiators are plastic, and the aluminum parts are coated with a protectant, it takes a while.
  14. Feb 23, 2009 at 7:49 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Wow, never. A more common problem with the radiators in the 4Runners with the 5VZ engine also been reported in the Tacoma's. There are multiple instances of strawberry milkshakes with these radiators. Personally I am going to do it just to save the potential headache of it happening.
    Example 1.
    Example 2.
    Example 3.
  15. Feb 24, 2009 at 3:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wow! Interesting. I have heard of it now. :(
