Transmition lurch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Artur R, May 17, 2023.
  1. May 17, 2023 at 3:55 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    You don't want the truck to move while you're putting it in gear. Make sure your securely on the brake pedal.
    gudujarlson likes this.
  2. May 17, 2023 at 4:16 PM
    Artur R
    Artur R [OP] Member
    Artur
    2023 black toyota tacoma trd pro
    I don't understand why is everyone thinking I'm not doing it right. It's not my first car. Why do I need to slam the breaks in order to have this issue go away. I'm not idling the truck. It's all normal rpm (about 700) and it's still doing it. It's not normal and whay do I have to have different routine driving than all my other trucks.
    usmc2msu likes this.
  3. May 17, 2023 at 4:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I don’t know what you’ve owned before, but the taco 3.5L is rated for 270HP and in high idle situations it will definitely surprise you when you put it in drive without enough brake application
    zoo truck and Chew like this.
  4. May 17, 2023 at 4:24 PM
    Irishblessing
    Irishblessing So Cal Is Where My Mind States
    2023 Tacoma OR
    I would say I had similar indications as described aside from the "metal sound". I wait until idle to stabilize before shifting into gear. I still get the jerking motion when trying to back into a space- stopping and going while parking- however issue has become less noticeable as I put some miles on the truck.
    Not sure if this is correct at all but I believe these trucks have auto locking/unlocking torque converters and that maybe it locking and unlocking while coasting, maybe someone else can confirm this.
  5. May 17, 2023 at 4:37 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Check the u joints with the rear end off the ground and report back. Hell, if one has failed, you might not need to lift the tires free to find it. A small lurch is normal when changing directions, a big one indicates there is slacl being taken up somewhere, especially if its a bigger lurch when changing direction, compared to when just outting the transmission in drive or reverse from park.
  6. May 17, 2023 at 4:59 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Check fluid level
    cryptolime likes this.
  7. May 17, 2023 at 5:55 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    OP, I'm sorry. this is how TW works. You get lots of answers that you don't need, lots that don't relate, and sometimes useful things.
    Zuba Gooding Jr and usmc2msu like this.
  8. May 17, 2023 at 5:55 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Did you try it or just dismiss their suggestion?
    auskip07 likes this.
  9. May 18, 2023 at 4:54 AM
    Artur R
    Artur R [OP] Member
    Artur
    Why would I want todeal with noise and jerking transmition on brand new truck. I did what they said but the problem is still there. Do you normally saddle for half if you you paid for full?
    Zuba Gooding Jr likes this.
  10. May 18, 2023 at 4:57 AM
    deaps
    deaps Well-Known Member
    2023 TRD OR
    I've noticed this - if I start the vehicle, keep my foot on the brake, and then put it in drive - it will lurch forward and almost start rolling on its own.
    To remedy thidy this I - start the vehicle, remove my foot from the brake, re-hit the brake, and then put it in drive.
    I think it's because the brake booster has no boost the first time you apply the brake, while the engine is off...so it's a really weak application of the brakes. Once it's started, and the vacuum system has even 3 seconds to build boost, if you re-apply the brake, it is a more firm (and boosted) application of the brakes. This prevents any lurch when putting the transmission into a drive gear from Park.
    Because we all own the same truck as you, and experience the same thing as you. Furthermore, the dealership checked it and gave you the solution. Should you choose to listen - or keep thinking your vehicle is defective is up to you.
  11. May 18, 2023 at 5:02 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    mine does this in the morning, i park backwards in the garage and i dont want to wait for my garage to fill up with exhaust so i shift within a few seconds of start up and idle out of the garage. Its normal
  12. May 18, 2023 at 9:54 AM
    Artur R
    Artur R [OP] Member
    Artur
    And because we all own the same truck it doesn't mean it's okay for it to be wrong. I don't need to settle for some crap excuse from dealership telling me it's normal and I don't understand why would you too unless you work for the dealership. If you would have buy TV and only half of the screen was off and the sales person or technician told you that's normal because 100 other users have the same issue, would you agree with them?
  13. May 18, 2023 at 9:58 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    At many dealerships everything is "normal" because they want to do as little warranty work as possible instead of prioritizing satisfying the customer. If you're not satisfied, try another dealership. You're under no obligation to have it serviced where you bought it.
    HondaGM and Zuba Gooding Jr like this.
  14. May 18, 2023 at 9:59 AM
    auskip07
    Skip
    Atlanta, Ga
    the noise is likely the auto trans parking pin releasing or driveline tolarances responding to tension. I dont know if this is something to "deal with" its just a characteristic of the truck.
    the best way to ruin a car ownership experience is to try to fix problems that dont exist.
  15. May 18, 2023 at 10:03 AM
    #35
    Artur R
    Artur R [OP] Member
    Artur
    Ok. Now this sounds like legit answer to my question
    HondaGM likes this.
  16. May 18, 2023 at 10:08 AM
    #36
    JingstogOR
    JingstogOR Active Member
    23 Electric Lime TRD OR 4x4
    My first 21 OR Tacoma did this. My second 23 OR Tacoma does this. My dad's 19 SR5 does this. My good friends 20 OR Tacoma did this. I've personally driven 4 different tacos, and they all did this.
  17. May 18, 2023 at 10:14 AM
    #37
    deaps
    2023 TRD OR
    lol...and we have no reason to lie to you - nor are we there to feel what you are feeling (but the dealership was) - and they make money to fix it - Toyota *pays them* to fix any problem that exists.
    That said - we all notice the same issue when the pedal isn't pressed firmly - whether that be from low vacuum boost (from initial starting) - or from not pressing the pedal hard enough. All of us. Every single one of us. The fact that the dealership told you to press the brake pedal more firmly cements our suspicion that you need to press the brake pedal more firmly.
    So no, a tv not working is completely different. You expect that you can change gears and not have the vehicle momentum change and start going if the brake pedal isn't firmly applied?
    At the end of the day, we could certainly be wrong - and there could be a major concern with your truck - but we've all experienced it, we've tried to help, so not sure why the attitude.
    Yeah...and you know how you eliminate that? By pressing firmly on the brake pedal when you shift...and by applying the parking brake FULLY before putting it into park if parking on an incline - before the vehicle comes to rest on the parking pawl.
  18. May 18, 2023 at 10:18 AM
    #38
    auskip07
    Skip
    Atlanta, Ga
    LOL, yes but if you park on any type of incline your pin will be under tension and would result in a less than smooth release.
    HondaGM likes this.
  19. May 18, 2023 at 10:19 AM
    #39
    deaps
    2023 TRD OR
    It doesn't rest on the parking pawl if you apply the emergency brake properly, and let the emergency brake hold the vehicle - as it was designed, before putting it in park so it never rests on the parking pawl. Your parking pawl will never be under that tension - unless the emergency brake fails to hold the vehicle. Period.
  20. May 18, 2023 at 10:20 AM
    #40
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    then people will complain they have to actually use the parking brake as designed :rolleyes:
    HondaGM and deaps[QUOTED] like this.
