Transmition lurch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Artur R, May 17, 2023.
  1. May 18, 2023 at 10:21 AM
    #41
    deaps
    deaps Well-Known Member
    2023 TRD OR
    Bro it's like - didn't these people learn how a vehicle works at age 16?
    zoo truck and HondaGM like this.
  2. May 18, 2023 at 10:25 AM
    #42
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    most people who drive Autos dont use the parking brake. i honestly dont use it unless im parking on a surface grade that would warrant it.
    zoo truck likes this.
  3. May 18, 2023 at 10:27 AM
    #43
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I certainly did, but then again the driver's ed simulator I learned on was a 3 speed column shift, so the parking brake took on a more major role :anonymous:
    deaps[QUOTED], HondaGM and auskip07 like this.
  4. May 18, 2023 at 10:30 AM
    #44
    auskip07
    Skip
    Atlanta, Ga
    we must have learned on the same type of simulator
  5. May 18, 2023 at 10:42 AM
    #45
    Artur R
    Artur R [OP] Member
    Artur
    2023 black toyota tacoma trd pro
    I have 4 other cars at home and not one does it except tacoma, how is this normal and why are you all talking about break. How is this normal. You push your brake before you put it on D. The car make clunky noise and jerks forward. How is this normal? If that's how it's designed than I guess I'll deal with it but I don't know if you guys ever drove car or truck thst don't do that. Is crazy what I'm seeing on here.
  6. May 18, 2023 at 10:44 AM
    #46
    Artur R
    Artur R [OP] Member
    Artur
    Automatic transmission should not make noise when engaging into gear and definitely should not jerk forward like the gears wore engaging with out clutch
  7. May 18, 2023 at 10:46 AM
    #47
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I would go back to the dealer,or find another one...walk the lot and find a truck the same as yours,and ask to test drive it.If another one does it ,its a Characteristic of the truck..I have a 23 and dont notice what your describing
  8. May 18, 2023 at 11:07 AM
    #48
    deaps
    2023 TRD OR
    I dunno my first truck was an 89 toyota pickup with a 5sp manual. It had that old school ebrake that you pulled OUT from the dash...and twisted to let go. It never worked. So I had to carry a 4x4 block in the bed o_O ... that was my true ebrake.
    FL_TRD Sport[QUOTED] likes this.
  9. May 18, 2023 at 11:10 AM
    #49
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Since we’re not the decision makers here, and you know that, why not go argue with the ones that are?
    Sell it, be happy, move on. As they say; Life is too short to deal with clunks and forward lurches.
  10. May 18, 2023 at 11:31 AM
    #50
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    When someone says lurch I think of....
    auskip07 likes this.
  11. May 18, 2023 at 12:15 PM
    #51
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Going from reverse to drive there shouldn’t be any lurching forward. Brakes should be applied and vehicle stopped before shifting from my reverse to drive. If you don’t you will have issues with the drivetrain.
    There might be a more of a jerk as stated before if you shift out of park right after you first start it. Wait for the start up cycle to slow and change programming. Takes about 15 to 20 seconds.
    If your truck is physically rolling forward when you shift from park to drive and the brake pedal is depressed you have an issue.
    As for the clunking, every one of my rwd vehicles have done it in one form or another. Never caused an issue.
    You are going to feel something every time you put a rwd vehicle into d from park with the brake on. The transmission uses fluid pressure. That pressure is suddenly rerouted through the valve bodies when you shift out of park. The body’s instant shifting of pressure surges the torque converter. The only place for that to go is into the driveline after the transmission ie the driveshaft. Driveshaft to rear end. Only thing to absorb that force with foot on the brake is u joints and rear diff. That where the clunk comes from. The rear diff gears are always engaged. Different lash setting on the rear gears produces different amounts and direction of movement between the gears when that shock travels from the transmission to the rear diff.
    These trucks have quirks. Every one is different even one built right next to each other on the line. Even dimensions and measurements are different.
    Drive it and enjoy it. If it bothers you trade it in. You have been some really good advice as to how to proceed. If you don’t agree with the advice don’t argue. Just move on and try something else. Best of luck.
    And FYI mines clunks a bit when putting it into gear. I trust it enough to take it into the middle of nowhere in Wyoming and Montana. Where I am now.
  12. May 18, 2023 at 12:20 PM
    #52
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Suggestion for TW: thick skin.
    FlyingWolfe and deaps like this.
  13. May 18, 2023 at 12:29 PM
    #53
    PTSDTherapy
    22 SR5 DCSB
    Agreed. I learned thick skin when I first got stationed in Hawaii. It was worth being called a haole and not being invited to a lot of things. After I was accepted everything changed. If I didn’t have thick skin then I wouldn’t have the friends there now that I have to this day.
    Then I joined TW and had to remember the thick skin. Hehehe.
    Ua ola no i ka pane a ke aloha
    There is life in a kindly reply.
  14. May 18, 2023 at 12:51 PM
    #54
    Nuked
    Nuked Active Member
    Morgantown, WV
    2020 TRD OR DCSB 4x4
    OP mine does the same thing. I am going to do a drain/check/fill on the transmission fluid this week and see if it helps, not because of this issue but the fact the truck runs and drives like shit.
  15. May 18, 2023 at 2:14 PM
    #55
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You need to try another truck or two on the dealers lot. If they all do it you either have to live with it or sell it.
    Just because something doesn’t operate like you want it to doesn’t mean it’s broken…..especially if other trucks exhibit the same condition.
    If other trucks exhibit the same condition, it is normal and the dealer cannot “re-engineer” your truck.
    Chew likes this.
  16. May 18, 2023 at 2:16 PM
    #56
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Can somebody please change the title....
  17. May 18, 2023 at 4:14 PM
    #57
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I gotta admit I only use the parking brake on my truck when parked on a grade also.
  18. May 18, 2023 at 4:22 PM
    #58
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    HondaGM[QUOTED] likes this.
  19. May 18, 2023 at 4:37 PM
    #59
    tonestar
    tonestar Well-Known Member
    Anthony
    NY
    2015 Taco 4x4 V6
    Typical quirky activities from this mini van engine/ gas mileage hunting transmission. Trade it, wait for the 4th gen to smooth out the drivetrain IMO
  20. May 18, 2023 at 5:02 PM
    #60
    forana
    Kaneohe, Hawaii
    yeah, good lesson. Everyone makes fun of everyone in Hawaii. Then outsiders get mad and offended and try to change culture here. Never goes over well.
    https://www.youtube.com/watch?v=XyB_vaO47KY
