Transport 1x6 decking boards - max length?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymoussy, Jun 29, 2015.
  1. Jun 29, 2015 at 3:21 PM
    jaymoussy
    jaymoussy [OP] Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    I need to replace some decking boards (cedar, 40 years old!), going to pick up 1x6 PT boards in my long bed, no rack.
    Boards come in 10, 12 and 16 feet, and I only need a very few in 16 ft length.
    I wonder how long I can get away with, boards flat in the bed, with the addition of the puny Harbor Freight extension?
  2. Jun 29, 2015 at 3:32 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Could you put a red handkerchief on the end of a board and hope you get home B 4 U get stopped ?
  3. Jun 29, 2015 at 3:37 PM
    CamoNBlaze
    CamoNBlaze Well-Known Member
    Zach
    '09 V6, 6 speed
    Just strap them down well.... As long as you flag the end and its light out you should be fine... I've had a 16 foot canoe tied in this way....
  4. Jun 29, 2015 at 3:43 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Most states require a red flag or red light on loads extending more than 4 feet beyond the rear of the vehicle why don't you just use a thick pad [old sleeping bag, furniture pad etc.] and load them extending over the cab with the back extending no more than 4 feet and secure them with a couple of ratchet straps.
  5. Jun 29, 2015 at 3:49 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Place the 16' footers in first, then pile on the smaller ones over them..... all against the front bed wall.... with straps. Good to go!
  6. Jun 29, 2015 at 5:51 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Throw an old blanket folded up nicely on top of the cab and open the tail gate, use ratchet straps
    I used to do it all the time with a fair bit of lumber. Never an issue
  7. Jun 29, 2015 at 6:12 PM
    dcaplan
    dcaplan Well-Known Member
    Drew
    Fergus, ON
    2020 4Runner Venture
    I was transporting 16' boards the other day and I put a few sand bags on the one end of them to keep them in the bed and not bouncing out (plus a tie-down). Still not fun and I was glad to get home.
  8. Jun 29, 2015 at 6:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How many boards total would you need ?
  9. Jun 29, 2015 at 11:50 PM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    This^
    But it all depends on how far you're driving, and how busy those roads will be....
  10. Jun 30, 2015 at 4:01 AM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Do you have a rear sliding window? This is the main reason I get one and probably the only time I use it. Just slide the boards through that and rest them on the top of the tailgate and use ratchet straps. you can put the smaller boards on either side of them, the will be angled forward and when strapped down shouldn't want to move anywhere. I usually get them up to the dash and just use a rag and hope I don't scratch anything - but its a truck and that's why I bought it.
  11. Jun 30, 2015 at 4:43 AM
    jaymoussy
    Eastern MA, US
    '12 AC Base 2.7l 4a
    All good ideas, thanks.
    I will run a test around neighborhood quiet roads with the blanket-over-cab + straps method.
  12. Jun 30, 2015 at 6:05 AM
    patbegley
    The Kootenays
    '22 DCLB
    And then take a picture;)
    With the tail gate down, a good way to lock the tails of lumber is from the trailer hitch with a full loop around the lumber with your ratchet strap.
  13. Jun 30, 2015 at 7:42 AM
    OZ-T
    Peter North
    British Columbia
    Buy a headache rack , problem solved
