Transporting ATV on truck bead
Discussion in 'All Terrain Vehicles' started by icefox, Jun 6, 2011.
  1. Jun 6, 2011 at 9:10 AM
    icefox
    icefox [OP] Well-Known Member
    Fridfinnur
    Iceland
    Toyota Hilux
    38" tires,3"lift,diff lock fornt and rear
    Hi anyone know if I can fit a Polaris Sportsman 850 on the truck bead of a Tacoma double cap. The dimensions fit some what but I don't know how far from the front end the front wheels are on the ATV so is anyone transporting there Polaris on there truck bead and willing to share info on this.
  2. Jun 6, 2011 at 9:22 AM
    icefox
    Fridfinnur
    Iceland
    Toyota Hilux
    I dont have a long bed and the overall length of the ATV is longer than the truck bed and the tailgate but where are the weels of the ATV relative to the front end and the back end of the ATV. will the wheels and front end fit on the bed? That is the big question.
  3. Jun 6, 2011 at 9:24 AM
    chrisman8995
    chrisman8995 Well-Known Member
    Newnan, GA
    05 PreRunner Double Cab
    my honda foretrax will barely fit with a long bed. Tailgate down and back window open b/c of my winch. i'm very careful and put it in the truck as a last resort im afraid it will come up and bust the back window. its honestly about an inch away from the window. hope that helps
  4. Jun 6, 2011 at 11:14 AM
    icefox
    Fridfinnur
    Iceland
    Toyota Hilux
    Hummm then I think the polaris 850 is not going on to my truck bed
    Tnx
  5. Jun 6, 2011 at 11:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would guess it would fit, hopefully someone else has done it to confirm though. Here's how'd I'd load it, I would put a 2x8 across the front on top of the wheel wells so the front end sits up on the wells. That will make the back end come forward a little bit more but it'll put a lot of weight on the tailgate.
  6. Jun 7, 2011 at 8:05 PM
    jeanyves
    jeanyves not junior member
    red deer
    08 trd offroad
    lr uca,trd supercharger,light bar ,4 lightforce striker 170,toyota alu. step for winter,black nfab for summer,fog light mod,toytec ultimate lift kit with 5100,18'' fuel boost with 275/65 nitto terra grappler
    well i recently bought a grizzly 700 with 26 mudlite,and it barely fit,i had to shim the front to not hit the window,had no room to secure the front,was making the truck top heavy and had no room for gear anymore ,so i just bought a trailer instead.i should mention that i use my oem cargo divider and put some 2x4 between the divider and the front of the bed and drove the quad against it,makes it safe for when you brake hard so the quad don t hit the window and it work really good for that:headbang:
    before
    after
  7. Jun 8, 2011 at 4:17 PM
    icefox
    Fridfinnur
    Iceland
    Toyota Hilux
    Nice setup. I think I go for some kind of trailer, they are just so gd expensive in Iceland.
  8. Jun 23, 2011 at 10:46 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Dbl cab long bed
    3in spacer
    My 700 Grizzly with 27in tires fits in the back of my 02 ExtraCab Taco with the tail gate down, if I level out the wheel wells I can close the gate. My front tires hit the box so there is now worries of anything hitting the cab or glass.
