Transporting Plywood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slomatt, Dec 10, 2017.
  1. Jan 28, 2019 at 6:01 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    With the risk of damaging the tailgate, I’d rent a Home Depot truck for $19 to move something like this. That’s just me though.... Cost/benefit
  2. Jan 28, 2019 at 6:43 AM
    dbennett48
    dbennett48 Member
    Dave
    Ukiah, CA
    2006 Tacoma Access Cab,5 spd.
    Totally Stock
    I have one of the Harbor Freight bed extenders. Works great.
    bluezzy[QUOTED] likes this.
  3. Jan 28, 2019 at 10:28 PM
    slomatt
    slomatt [OP] Active Member
    Bay Area, CA
    2010 DCSB TRD OR
    Actually, if you look closely at the pictures the rails are notched so that they do not touch the tailgate. All the weight of the load is supported by the notches in the side of the bed and the floor of the bed (which are both designed to be load bearing), no weight is applied to the tailgate.
    Delivery costs for small loads like this would be close to the total price of the materials I'm picking up. Renting a HD truck would require twice the driving time. It took me about 2 hours to build the plywood rack and it has been extremely useful, especially for weekend projects where I just need to pick up a few sheets of plywood or drywall.
    Rick's 2012 likes this.
  4. Jan 29, 2019 at 4:19 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I don’t see where the rack is notched so that it puts zero weight on the tailgate. It looks like it lays right on it. Maybe a different picture?
    I don’t like the bed racks because they decrease payload and now thats one more thing I don’t have space for in my garage. Plus 50% of the load is hanging out the truck and wrenching on the axle.
    That’s why I always go with a 6ft+ bed.
  5. Jan 29, 2019 at 6:22 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Lotta work and expense for virtually no gain IMO. Just leave the tailgate up and slide the plywood in the truck. The bed is 5' and with the gate up you have less than 3' extending and only a fraction of the weight on the gate since the load is angled down toward the cab.
    I also have a bed extender and with it folded down I can easily handle stuff up to 10' long.
    06Tacooo and PackCon like this.
  6. Jan 29, 2019 at 6:47 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Nice work OP but I do agree it seems like a lot of work to transport wood. I do see the notch cut out for the tailgate in the pre-assembled pics in the first post but a hitch bed extender and some scrap 2x4's would be much simpler.
    PackCon likes this.
  7. Jan 29, 2019 at 12:20 PM
    vtdog
    vtdog Well-Known Member
    NH
    I transport plywood by putting the 2x4 under the plywood sheet. I keep the tailgate up, and the weight falls on the 2x4s. I use straps around the plywood and the bed hooks. Never had an issue, but I do have a steel tailgate cap from voodoo.
    Sudsman44 likes this.
  8. Jan 29, 2019 at 5:08 PM
    Bobcdn
    Bobcdn Well-Known Member
    WTB; 2nd gen well built Tacoma
    Nice set up! Well put together as well.
    I am a wood worker and move sheet goods around that can't get marked up- so this set up would work good for my needs- where having it leaning on the tail gate would mark it up too much for my uses.
    I usually use a trailer for sheet goods so I can lay them flat- but this set up would be better than lugging the trailer all the time.
  9. Jan 29, 2019 at 10:47 PM
    slomatt
    Bay Area, CA
    2010 DCSB TRD OR
    The notch can be seen in the 2nd picture. The rack does some take some garage space, but it comes apart and stores flat and pretty much disappears into a corner. Given that the Tacoma is rated for hundreds of pounds of tongue weight when towing I don't think having ~100lbs of lumber hanging out is a concern. The majority of the weight is carried by the pockets in the side of the bed, the remaining is carried by the rails which are cantilevered out over the tailgate.
    Thanks, one main motivation for this setup was to be able to transfer sheet stock without chipping the edges or dinging the faces. I also wanted to have full length support for transporting drywall, if it's just leaning on the tail gate it can snap or the paper can get torn.
    PackCon[QUOTED] likes this.
  10. Jan 30, 2019 at 7:47 AM
    96carboard
    96carboard Well-Known Member
    Wow, lots of work for an imaginary problem.
    If there was a problem that needed to be fixed, I would have found it by now in one of my many loads of drywall, never fewer than 2 dozen.
  11. Jan 30, 2019 at 7:53 AM
    la0d0g
    running for the hills
    For crawling not hauling
    The tailgates being weak POS on these trucks is not an imaginary problem. There's a lot of documented instances of them being weak. That being said, I just hang plywood over the top of mine too.
  12. Jan 30, 2019 at 7:56 AM
    96carboard
    First of all, only when severely abused.
    Second, you can bend the tailgate on ANY truck. They're ALL just made out of sheet metal.
    And THIRD and probably most importantly, only when the tailgate is DOWN.
  13. Jan 30, 2019 at 8:38 AM
    la0d0g
    I disagree with all three of your points though only marginally with your last one since I do agree the tailgate being vertical makes it much less prone to damage. Still no denying their still shit tailgates, not that I expected much from them.
  14. Jan 30, 2019 at 9:19 AM
    Bobcdn
    I plan on building this set up for my 6' bed. Some of the veneered sheet goods can be quite expensive (few hundred dollars a sheet) any damage done during transport to the edges or face can ruin an entire sheet.
    I'd bet you can safely stack more weight on top of this set up than you can lean on the tail gate. When it's leaned on the tail gate it is the latches that are bearing the weight and lets not forget that the boxes are so weak on these trucks that 'bed stiffeners' have to be added to stop the bed sides from cracking the light sheet metal that supports the tail gate and leaning out to the sides- that means less of the tail gate latch is engaged- now you stack a bunch of weigh on there and then go over bumps that will increase the force... If you had enough weigh on the tail gate and had to do an emergency lane change you could end up with a flat bed!:D
    Not saying that it will happen if you lean weight on your tail gate- just saying with these cheaply built Tacomas there will be less possibility for disaster by using something that transfers the weight to the bed floor over top of the frame mounting points- rather than assuming your tail gate latches will hold it. After all it is the people behind you that ultimately pay the price for your poorly secured load!:crapstorm:
    la0d0g likes this.
  15. Jan 30, 2019 at 9:28 AM
    #35
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Yeah, this, and prob about the same cost. I have a lund version that supports 700 lbs, great for my kayaks as well
  16. Jan 30, 2019 at 9:44 AM
    #36
    yahoopaul
    yahoopaul Well-Known Member
    Great idea
  17. Jan 31, 2019 at 5:27 AM
    #37
    96carboard
    And that is exactly what is wonderful about reality. Whether you agree or not has no absolutely no impact.
  18. Jan 31, 2019 at 5:39 AM
    #38
    la0d0g
  19. Feb 19, 2019 at 3:48 PM
    #39
    Oh_deer
    Oh_deer Supreme Commander Sullivan County Deer Chasers
    David
    Brooklyn & Upstate NY
    2018 OR DCLB Inferno
    Thanks slomatt, for the awesome idea and picts. I’ll be building one soon!
    I do agree that some of the plywood panels are freaking expensive and having a way to securely transport them is always a win!
    Let’s not even mention the fragile drywall panels, lol!
    - David
  20. Jan 21, 2020 at 3:34 PM
    #40
    Bobcdn
    I am planning on building one of these for my long bed. I am wondering about hinging the two long pieces so that they fold and fit in the bed with the tailgate closed?
