Transtercase... I'm confused...
Discussion in 'Technical Chat' started by Eesh, Aug 17, 2010.
  1. Aug 17, 2010 at 7:32 PM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Sorry guys this is my first time doing this. I have an 06 trd 4x4 sport. I just changed the front and rear diff.
    The transfer case is different than the transmission?? Correct? How do I locate the transfer case? What does it look like? What does the transmission look like?
  2. Aug 17, 2010 at 7:42 PM
    Eesh
    trd Sport
    Ok and where is the Front diff?
  3. Aug 18, 2010 at 10:48 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    ummm....ok, I'll bite...
    How the he77 did you replace the front diff if you don't know where it is?:confused:
  4. Aug 18, 2010 at 10:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yeah, some things are just better left unsaid...
  5. Aug 18, 2010 at 10:53 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Aug 18, 2010 at 10:54 AM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    hmm..... Diffs are in between each set of wheels (roughly soccerball sized metal cases). each of them has a driveshaft coming out of it heading in the general direction of the center of the truck. the box they meet at is the t-case. Good luck.
  7. Aug 18, 2010 at 10:55 AM
    Pugga
    Massachusetts
    Before you go on the adventure of changing the oil in the front and rear differential and transfer case, you may want to employ a buddy who's done it before. Beer and pizza usually works well as payment. It's not hard but it'll go a lot smoother and you may learn some other tricks and hints if you have someone there who knows what they're doing. Also, check out the DIY section on TW, I believe there's a DIY diff oil change.
  8. Aug 18, 2010 at 10:57 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The transfer case is connected to your transmission. It's engine, transmisson, transfer case, rear drive shaft, rear diff. For the front: front drive shaft, front diff and front CV driveshaft...
  9. Aug 18, 2010 at 10:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    Transmission
    Front diff
    Transfer case
