Travel Trailer vs Fifth Wheel
Discussion in 'Towing' started by morphiend, May 31, 2010.
  1. May 31, 2010 at 7:21 PM
    morphiend
    morphiend [OP] Member
    I'm looking at getting a trailer and was focusing on travel trailers. Then I got wondering why no one seems to pull fifth wheels with their Tacomas. Any insight?
  2. May 31, 2010 at 7:26 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Good question!!!
  3. May 31, 2010 at 7:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I have not heard of anyone pulling a 5th wheel trailer with a taco.
  4. Jun 3, 2010 at 4:27 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    If you want to pull a fifth wheeler, then the tacoma isn't right for you. It's not set up for that.
  5. Jun 3, 2010 at 9:38 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    why havent you seen 5th wheels on tacos?? cuz a tacoma, along with a sonoma, s-10 and canyon ect are classified as "compact" trucks. And the suspension and drive assembaly are not near strong enough or powerfull enough so pull one.
    haha yup.
  6. Jun 3, 2010 at 9:50 PM
    FFRNDAN
    FFRNDAN Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    Its been done. 5th wheels pull much easier (handling wise) than a traditional travel trailer. I'll have to find the thread of a ZR2 S10 pulling a decent size 5th wheel.
  7. Jun 3, 2010 at 9:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    hahahaha please do. I wanna see this!!
  8. Jun 5, 2010 at 1:14 AM
    08BlackTacoma
    08BlackTacoma Well-Known Member
    South Florida
    09' Double Cab V6 SR5, Long Bed, TRD Sport
    actually the owners manual talks about 5th wheel towing. it is fine, as long as you stay in its capactity.
    Here are pics of many smaller trucks with a 5th wheel. obviously if you exceed its capacity then your a dumbass, but staying in its capacity 5th wheel towing is very safe.
  9. Jun 5, 2010 at 10:45 PM
    morphiend
    I have seen quite a few 5th's that are with in the towing capacity of a Tacoma, so I don't think it is an issue of whether or not it can be done. There also seems to be a pretty large following that 5th wheel's are more "safe" and easier to handle then their travel trailer counterparts. From what I've found the 5th wheels that are tower are far least common then travel trailers. As well, for similar size and setup, they seem to be a bit more expensive. Perhaps these are the reasons?
  10. Jun 5, 2010 at 10:56 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i just dont know how well the composite bed will put up with the 5th wheel unless it was tied into the truck some other way?????
  11. Jun 5, 2010 at 11:15 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2 needs something supporting it
