traveling cross country and p0351 code came up
Discussion in 'Technical Chat' started by seksilumpia, Oct 23, 2011.
  1. Oct 23, 2011 at 10:01 PM
    seksilumpia
    seksilumpia [OP] Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    does anyone know what it is exactly?id try and look it up myself but im getting poor or no connection..thanks for any help or suggestions,i drove from gulfport Ms. to El paso Tx today and im worried if im doing futher damage
  2. Oct 23, 2011 at 10:15 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
    I'd reset your ECU and see if it comes back.
  3. Oct 23, 2011 at 10:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Just a quick google search shows that code to mean there is a problem with the number one cylinder ignition coil.
    If it runs okay and does not miss, I would pull the negative battery cable for a couple minutes to reset the computer and keep driving it. I did that on a Jeep with the same type of trouble code and it never did come back.
    If it is missing, then you can damage the catalytic converters and possibly the engine itself. If you are noticing any significant lack of power, stumbling, shaking, etc, then it needs to be dealt with asap.
  4. Oct 23, 2011 at 10:20 PM
    KalamaKid
    Oregon
    There is also this... not sure what it means.
    "MIL "ON" DTC P0351, P0352, P0353, P0354, P0355, P0356 (T-SB-0047-10)
    Some 2008 – 2010 model year vehicles equipped with 2GR-FE engines may exhibit a MIL “ON” condition with Diagnostic Trouble Code (DTC) P0351, P0352, P0353, P0354, P0355, or P0356 (Ignition Coil Primary/Secondary Circuit) stored in the Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM)."
    http://www.autoproimportrepair.com/technical_service_bulletin_index.htm
    Says there is a TSB about it :notsure:
  5. Oct 24, 2011 at 11:35 AM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Thanks Tacoma family..I reset the light and it did come back on within 40 miles..I'm going to switch out the ignition coil when we stop for the night..I'll look at all of the coils but for quick reference, primary coil on 6cyl 07 camry is front passenger side,right?
  6. Oct 24, 2011 at 6:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I believe that's correct.
    But you should read that TSB above. If it's still running good, might just be a ghost in the computer.
