TRD 110V plug for 4X4 w/SR5 PKG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Speed8082, Sep 6, 2009.
  1. Sep 6, 2009 at 12:46 PM
    Speed8082
    Speed8082 [OP] Member
    Coxs Creek, KY
    05 4X4 Double Cab
    Cap
    Hi, I'm new to TW and a novice Tacoma Owner. I've had my 2005 DBL Cab 4X4 L/B w/SR5 pkg #8 since 2006.
    A friend said that the TRD's had a 110V plug located where I have the storage box in the bed of my truck. He said the plug had an on/off switch located in the cab.
    My question is, can I buy the parts to connect to the factory wiring harness in order to have this feature on my truck? I would very much like to be able to plug in a TV while tailgating so that I can watch football while waiting on my game to start.
    Thanks in advance, gald to have found this site.
  2. Sep 6, 2009 at 12:59 PM
    JKD
    JKD Well-Known Member
    It would be way, way easier to just run a 12v accessory outlet to the bed, and buy a standard 120v converter that plugs into that outlet.
  3. Sep 6, 2009 at 1:11 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    And cheaper
  4. Sep 6, 2009 at 1:19 PM
    JKD
  5. Sep 6, 2009 at 1:27 PM
    JayAre
    JayAre Well-Known Member
    OR
    13 TRD Sport DCLB
    Is the stock one even powerful enough to run a TV? I haven't used mine yet, but I have a 400w inverter and it wouldn't even run a laptop.
    I'd def. go with that 1500w inverter JKD posted.
  6. Sep 6, 2009 at 2:25 PM
    teri4lance
    teri4lance Well-Known Member
    SE Texas
    09 SR5 4x4
    Removed the price sticker in the window, bobbed 6" off the mudflaps, debadged. TSB completed.
  7. Sep 6, 2009 at 3:35 PM
    JKD
    Laptop power supplies typically draw under 100 watts; my 150 watt inverter has never had a problem with running one, and the 100w outlet in my wife's Pontiac Vibe always runs them fine.
    Something weird with your 400w inverter, I think.
  8. Sep 6, 2009 at 3:45 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I ran a 19" tv and a Directv DVR from my trucks outlet before. Worked fine.
    When the power went out in my neighborhood I was the only one on my street watching infomercials at 2 am.
  9. Sep 6, 2009 at 3:51 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    x2
    I ahve never used mine i dont even know if it works
  10. Sep 6, 2009 at 3:57 PM
    Speed8082
    Coxs Creek, KY
    05 4X4 Double Cab
    Cap
    Thanks, Never thought of using the tow plug. I sure am glad I found this sight.
  11. Sep 6, 2009 at 4:01 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    x2
    Would this have constant power(no need to have key in ignition)?
  12. Sep 6, 2009 at 6:19 PM
    Speed8082
    Coxs Creek, KY
    05 4X4 Double Cab
    Cap
    Not sure, Im planning on working on this next week. I'll let you know after I try it. If it requires the lights to be on etc, I'm going to add a "hot" 12V in the storage box.
  13. Sep 6, 2009 at 8:16 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
  14. Sep 6, 2009 at 8:29 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
  15. Sep 6, 2009 at 9:30 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
  16. Sep 8, 2009 at 6:19 PM
    deeznutz
    Seattle, WA
    09 SR5 DC LB 4x4
    Yes, please let me know how this turns out. :)
