TRD 2" Lift Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tim1985, Jan 6, 2024.
  1. Jan 6, 2024 at 3:28 PM
    Tim1985
    Tim1985 [OP] Member
    Tim
    2023 Tacoma TRD Off Road 4x4
    TRD Lift
    I purchased my 2023 Tacoma with the TRD lift kit. I'm not very knowledgeable with this stuff, but I'm looking to increase the lift on this kit about 1 inch on the front and rear. Just looking for some insight / opinions from more knowledgeable people on this.
    I'd like to have 3" on the front, and 2" on the back.
    I know this kit re-uses the stock coilovers. Would replacing the stock coilovers with larger ones increase the height from 2" to 3"?
    I know Wescott Designs has a preload collar kit for the Bilstein 5100 series, which is what the TRD kit uses. But I'm concerned about the ride quality going to shit with that setup.
    I'll more than likely be replacing the UCA's if I do all of this as well.
    I'd like to replace the U-bolts on the rear with a add a leaf kit to bring it up to 1.5-2" in the rear.
    I appreciate any advice I can get on this.
  2. Jan 6, 2024 at 3:54 PM
    TacoTuesday1
    FL
    Never heard of "TRD lift kit".
    People generally advise max 2" front.
    Spacers are bad.
    If you get 6112 for the front, they are height adjustable.
  3. Jan 6, 2024 at 3:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    2 - 2.5" up front is the sweet spot that allows the most mechanical empathy with the CVs and other components.
    Junkhead, 71tattooguy and Chew like this.
  4. Jan 6, 2024 at 4:00 PM
    Bishop84
    Bishop84 Well-Known Member
    Basically any more lift and it will drive like trash. You'd be better off buying a stock setup and putting a leveling kit 3 and 2 on it.
    The TRD lift is the sweet spot for tacoma and anymore causes issues with ball joints, wheel travel and overall driving quality.
    If you put the westcott lift on the TRD Kit it would max the front out and you'd have zero down travel.
    Honestly, just leave it. If you do anything just get bigger leaf springs in the rear if you want it to sit a little higher back there.
    SnuggleTruck, Irons and Chew like this.
  5. Jan 6, 2024 at 4:29 PM
    Tim1985
    Tim1985 [OP] Member
    Tim
    TRD Lift
    Thanks for the advice guys. Maybe I'll just increase the height through larger tires. I'm on 265/70/17's now.
  6. Jan 6, 2024 at 7:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    That's all that will increase clearance at the axle lines.
    You should find on OE wheels you can run 255 80 17, which is a full 33" dia.
    Junkhead and 71tattooguy like this.
  7. Jan 6, 2024 at 8:23 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  8. Jan 7, 2024 at 8:43 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    33" 255/80/17 is the way to go
  9. Jan 7, 2024 at 3:47 PM
    Tim1985
    Tim1985 [OP] Member
    Tim
    TRD Lift
    I'm on TRD pro wheels(+4 offset). I was already thinking pizza cutter 33's or 34's. I'll get a cmc and do any trimming necessary to fit the 34's if needed. Possibly regear down the line as well.
  10. Jan 14, 2024 at 5:55 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Hey, I'm looking at the same tire size. Do you have some pics of your truck with at least one from the side?
  11. Jan 14, 2024 at 10:23 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    This is the only pic I have. Saying goodbye to my awesome 5 year old 265/75/16 Duratracs, and moving up to my 255/80/17 Wildpeak AT3s.
    71tattooguy likes this.
