TRD 3.4 super charger from a 2000 4runner bolt on to a 2004 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MartinDWhite, Sep 27, 2016.
  1. Sep 27, 2016 at 7:04 AM
    MartinDWhite
    MartinDWhite [OP] Well-Known Member
    Martin
    Greenville, SC
    2004 4-dr 4x4 Tacoma TRD
    Relentless front and rear bumpers, Warn M-8000S Winch, Relentless RockSliders, bigger tires, bed cover RTT ... and more big changes in the works.
    There is a 4runner with a 3.4 and TRD super charger for sale at reasonable price. Will the supercharger come off the 4runner and bolt on to my 2004 3.4 V6 Tacoma? Are there any pitfalls or missing parts that I should be aware of? Anything I should check on a test drive?
  2. Sep 27, 2016 at 9:24 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Direct fit. The unit is pretty bullet proof, if it makes grinding noises it's bad. If he doesn't have a boost gauge I'd suggest bringing one and checking the boost level as that is a direct representation of its health. Depending on the pulley: stock 5-7 psi, 2.2" 6-9 psi, 2.1" 8-12 psi. You'll also want some type of fuel compensation for it. I'd recommend methanol injection. Do some research on it. A stage one kit should be adequate for low boost and will run around $200.
