TRD 3.4L Headers (PTR10-89990-07) for sale
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Kaiser, Dec 1, 2015.
  1. Dec 1, 2015 at 5:44 PM
    Kaiser
    Kaiser [OP] New Member
    Southern California
    04 TRD BAMF
    I have a set of used TRD headers I pulled off my ’04 Tacoma for sale. No issues with them, I had to pull them off in order to pass SMOG in the state of CA.
    Headers P/N 00602-17141-003Y-pipe P/N 17141-014
    Fits 5VZ-FE engine
    Tundra 3.4L V6 2000 – 2002
    Tacoma 3.4L V6 2000 – 2004
    4Runner 3.4L V6 1999-2002
    These should fit earlier model 5VZ-FE engines as well and will pass CA SMOG up to model year 2000 per executive order D-425-5
    Asking $500.00
    http://www.toyotaterritory.com/scripts/prodView.asp?idproduct=1548
    TRD 3.4L Headers (PTR10-89990-07)1201151644b.jpg 1201151645.jpg 1201151646.jpg
    Opticzlenz likes this.
  2. Dec 1, 2015 at 7:49 PM
    909DC5
    909DC5 Well-Known Member
    SoCal
    02 prerunner sr5
    if these are smog legal why did they make you take them off? I want headers on my truck but don't want to deal with removing them every 2 years:(
    Rocan likes this.
  3. Dec 1, 2015 at 10:05 PM
    Kaiser
    Southern California
    04 TRD BAMF
    I have an '04. Apparently the exception for these tubes on the engine only rolls up to model year 2000. Believe me, I looked for every damn exception I could find. Can find the document by googling D-425-5. Alternatively google Executive order D-425-12, this is the EO concerning model year thru 2003 (document was signed in 2003) all other part numbers for these headers EXCEPT those ending in 003. Bummer.
    So these may be legal in CA in the coming years, but because my truck is an 04, no dice.
    Long story short these should fit T-100 trucks using the same engine up to 1999 and pass smog in CA but I'm not totally positive. Buyers really should be living outside CA; I bought this truck out of Colorado
  4. Dec 1, 2015 at 11:18 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    If I already didn't have my Doug Thorley I would maybe jump on these. GLWS! How big of a PITA is that flange in the crossover that sits directly above the transmission?
  5. Dec 2, 2015 at 6:38 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    maybe it's just me but I'm failing to see why it would fail (I read the PDF). considering there are 6 other versions of the same pipes. would be interesting to see why they are not smog legal :notsure:
    If I had the spare cash I would consider but without any real performance boost to my non-modded 3.4 I can't justify :(
    GLWS!
  6. Dec 4, 2015 at 6:29 AM
    Jenkinstall
    Jenkinstall Active Member
    Jennings
    Colimbia, sc
    00 SC 4Runner Sport Edition 4wd
    Suspension/Drivetrain: 4wd swapped, E locker in rear with 4.30 gears, tundra 5100 adj. bilstein shocks, Trd coils, ome 891 springs with tundra shocks in back. Addicted offroad front tube bumper with BashFab hoops and stingaaaa, BashFab rear tube bumper, 285/75/16 BFG K02, tacoma wheels, savage offroad trans and t case skids and homemade gas tank skid. Engine: 2nd gen TRD SC, URD 7th, 2.2, TRD T-stat, IK-22 Plugs, TRD boost gauge, AEM wideband, ISR mod, and more to come. Interior: Kenwood marine stereo with Bluetooth
    Would you take 350 PayPal?
  7. Dec 4, 2015 at 8:01 AM
    909DC5
    SoCal
    02 prerunner sr5
    Looking for any trades? I have a full TRD cat back exhaust for the 01-04 tacoma if you are interested.
  8. Dec 30, 2015 at 12:52 AM
    Medina33
    Medina33 Well-Known Member
    Erik
    Lax
    2010 dcsb 4x4
    Still have them??
  9. Mar 9, 2019 at 7:41 PM
    mrscary
    mrscary Member
    Corona, CA
    2001 SR5 TRD Limited 4x4 3.4L V6 TRD Supercharger & TRD exhaust system
    SnugTop shell, K&N air filter, TRD Supercharger, TRD headers and exhaust
    I just registered my Supercharged Toyota 4x4 with the TRD 3.4L headers/exhaust system. The smog mechanic 'visually' failed my first attempt because the part number on my headers(00602-17141-003) wasn't listed in the latest CARB executive order update D-425-12. The reason is... D-425-12 only lists part numbers for the entire TRD exhaust systems, not separate parts individually as in the headers, the 'Y' collector pipe, the connector piece that welds to Catalytic Converter, etc. The TRD exhaust 'system' part number for my truck IS listed in the CARB EO (00602-17141-007). To clear this up with the smog tech that failed me, I downloaded a copy of the related exhaust system's installation instructions. The first page shows the system part #00602-17141-007 then lists the other part numbers in the kit. Including the numbers on the headers he referenced when failing my first smog check. The final hoop I had to jump thru, if you haven't guessed by now, to track down the correct, related, CARB D-425-12 Executive Order underhood sticker. Impossible. They don't exist. Officially. I had to design one to cover the correct wording, part numbers, and specs matching other CARB/TRD stickers, and have it printed. Passed without a problem. If you need one of these stickers I have eleven extras right now. $15.00 shipped. 20190309_162318.jpg
  10. Mar 10, 2019 at 12:22 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You should make the TRD supercharger CARB stickers, I'd definitely buy one.
  11. Mar 10, 2019 at 11:41 PM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    mrscary pm'd
    mrscary likes this.
  12. Mar 10, 2019 at 11:51 PM
    Opticzlenz
    Opticzlenz Member
    Michael
    1999 Tacoma TRD Off Road V6
    Clifford Remote Start Alpine Coaxial Speakers Alpine Bluetooth Deck
    I have a 99 trd off road taco wilk these fit and add more hp??
  13. Mar 11, 2019 at 12:13 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Thread was started in 2015...
  14. Mar 11, 2019 at 12:20 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I nearly had this same issue my last smog check with my TRD headers...the tech said that my headers only exempted up to 2003 Tacomas but not my 2004, but that he'd "let me slide" ....I thought that was strange because I have the CARB sticker for them under the hood. I really hope I dont run into trouble this year when I have to take the STAR test. I'll keep this in mind if I do run into trouble though.
    mrscary[QUOTED] likes this.
  15. Mar 11, 2019 at 12:37 AM
    Opticzlenz
    Opticzlenz Member
    Michael
    Im looking to buy some now
  16. Mar 11, 2019 at 12:46 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I passed a Star test in January of 2018 and easily passed with my 4cyl that has a Doug Thorley shorty header . The header has a CARB legal EO # D-540-6 stamp plate on cyl #1 Primary tube
    mrscary and Opticzlenz like this.
  17. Mar 11, 2019 at 1:02 AM
    Shortman5
    Supercharged TRD
    You, me and a whole lot of others would love to get some TRD long tubes. But they haven’t been made for years. Just keep in mind some of the early versions of the TRDs had leaking issues that were later revised with a updated design.
    EDIT: what I wa trying to say is that guy is long gone. Last login was 2016
    Opticzlenz[QUOTED] likes this.
  18. Mar 11, 2019 at 10:10 AM
    eon_blue
    Azusa, CA
    I passed too but the tech told me he was 'letting me slide' because my header's CARB sticker didn't cover the TRD headers for 2004 Tacomas, only up to 2003...which makes zero sense but I didn't want to argue with him since he was letting it go. But I'm worried about this year now because the STAR test is more strict. Anyhow I saved that sticker the OP posted in case I need to get one of my own created.
    mrscary likes this.
  19. Mar 11, 2019 at 10:18 AM
    Shortman5
    Supercharged TRD
    Let me know if your state forces you to get rid of them. I’d gladly help you out by taking them off your hands.
    eon_blue[QUOTED] likes this.
  20. Mar 11, 2019 at 10:20 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I know of a place up here in Hesperia that's a Star test facility that alot of supercharged vehicles go to and is recommended
    Moms smog
    16701 Walnut St A, Hesperia, CA 92345
    mrscary and eon_blue[QUOTED] like this.
