TRD 4x4 OR pulling ability or lack of in this case!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DJ TonyT, Apr 10, 2017.
  1. Apr 10, 2017 at 7:45 AM
    DJ TonyT
    DJ TonyT [OP] 2017 TRD 4x4 Off Road DCSB - Sunroof and JBL
    TonyT
    Jacksonville, FL
    Just wanted to post and tell everyone how dis-satisfied I am over the pulling ability of my Taco. My boat is a 19' MasterCraft, not that heavy or big but the Taco was struggling to keep up and my gas mileage almost dropped to half of what it was. It was my first time pulling anything at all.
    Anyone have any suggestions on settings I have on the vehicle that might help?
    Thanks!
  2. Apr 10, 2017 at 7:48 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Did you push the ECT button?
  3. Apr 10, 2017 at 7:52 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Did you press the ECT button? Also its pretty well documented between the Tacoma and Tundra anything over 5000 lbs the Tundra will be getting better gas mileage towing.
    DJ TonyT[QUOTED][OP] likes this.
  4. Apr 10, 2017 at 7:54 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
  5. Apr 10, 2017 at 7:57 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Wait, confused..... OP has a boat but says; "It was my first time pulling anything at all".
    How did you get said boat home? Plus with gear that's probably over 5K pounds... should have gotten a Full size or get a lighter boat.
    Better yet just rent a boat slip and leave the boat at marina.... problem solved.
  6. Apr 10, 2017 at 7:57 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    I didn't do anything other than hook my boat up and pull it. OK, so yes rlx02, that is a burn :). I will study my manual more next time. Thanks to all!
    So what does ECT do, I will read about it when I get back in my truck.
  7. Apr 10, 2017 at 7:58 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Did you check and see if there was a minivan motor under the hood?
  8. Apr 10, 2017 at 7:59 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    lol - when I bought the boat the guy delivered it to me.....seriously he did. Now that the weather has warmed up....its time to boat!
    bobrown14[QUOTED] likes this.
  9. Apr 10, 2017 at 7:59 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    How much does your boat AND trailer weigh? a Mastercraft can way up between 4-7k. Add the trailer and you are on the edge as far as tow capacity.
    I feel like this is common sense. A 3.5L V6 is not going to tow a lot and will suffer mpg loss.
    bobrown14 likes this.
  10. Apr 10, 2017 at 8:00 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Should have delivered to Toyota dealer and then take trucks for test drive with boat attached!
    Spare Parts and DJ TonyT[OP] like this.
  11. Apr 10, 2017 at 8:00 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    New towing Checklist:
    1) ECT ON
    2) Shifter in S mode (4th gear max since auto is double-overdrive)
    3) Credit card (for all the extra gas you're burning)
  12. Apr 10, 2017 at 8:01 AM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Sorry we're too busy being able to merge onto the highway without getting rear ended.
    PHLinPHX and Bannerman[QUOTED] like this.
  13. Apr 10, 2017 at 8:01 AM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    ECT will hold gears longer. But when you're towing that much weight you are pegged far down on the pedal so you'd be in high RPM anyway.
    You just have to get used to "towing" at 5k+ rpm, sadly thats how the truck is designed.
  14. Apr 10, 2017 at 8:02 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    OP could try fishing....many bass boats go fast as you wanna go and are usually a lot lighter and you get to go fishing with bro's....
    th365thli and Bannerman like this.
  15. Apr 10, 2017 at 8:03 AM
    Bannerman
    Johnson
    Charlotte, NC
    Eh, I'll keep my torque lower in the powerband vs a few extra HP up top, it is a truck after all, or it was. :crapstorm:
    JTM1 and RyanL like this.
  16. Apr 10, 2017 at 8:03 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    The MPG drop is expected. I average less than 12 MPGS in towing with my 2nd gen. Also, a 19ft mastercraft can weigh in at 5K lbs, close to the limit with these trucks so its understandable that you're experiencing all those issues. From what I gather, its normal. Try the ETC button, and don't expect too much towing capability out of a midsize truck.
    bobrown14 and DJ TonyT[OP] like this.
  17. Apr 10, 2017 at 8:03 AM
    c4lvinnn
    TIL: 30hp is "a few extra HP up top"
  18. Apr 10, 2017 at 8:04 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    I wish I could delete this post......lol
    But thanks guys.....I will do better next time!
  19. Apr 10, 2017 at 8:07 AM
    Bannerman
    Johnson
    Charlotte, NC
    Hey man, enjoy your Sienna
    bobrown14 and RyanL like this.
  20. Apr 10, 2017 at 8:08 AM
    JoeCOVA
    Joe
    Colorado Springs
    Eh if you look at the Dyno tests of both engines, they basically generate the same torque. The difference is the transmission and gears if any.
    T6A1C9O likes this.
