TRD 4x4 OR pulling ability or lack of in this case!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DJ TonyT, Apr 10, 2017.
  1. Apr 10, 2017 at 8:08 AM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    I will - it's great when I'm the slow truck in the right lane going 85 on our highways.
  2. Apr 10, 2017 at 8:08 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Just messin with ya.... 5K boats are hard to tow in a midsize...
  3. Apr 10, 2017 at 8:08 AM
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    If it your first time towing, you have a little of a learning curve. You shouldn't expect your taco to be able to perform like it's empty.
    Been towing bass boats for 20 years, taco is up to the task. Now is it the best not by far, but it does as well as older 1/2 tons I've used. As a all around between towing some and daily driver with lots of munervabilty it's great. Tow in the right gear , get brakes on your trailer (must) and drive conservatively and it will do the job. Now if you have 4 men and tons of gear and a heavily loaded master craft for skiing and have to drive far to the lake than you should have bought a full size jmho
    bobrown14 likes this.
  4. Apr 10, 2017 at 8:12 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    OP complains about gas mileage in truck and has a Mastercraft 19' boat! ummmm does not compute.
    Next outing... get gas in truck first then gas up boat.. will complain about gas mileage in boat instead of truck.
  5. Apr 10, 2017 at 8:14 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Correct, I believe it was only 500 rpm difference to achieve the same torque. The issue like you said is the transmission.
  6. Apr 10, 2017 at 8:19 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I'm just kidding guys, I'm sure your trucks are great. I test drove a '16 before I bought my '15 and was not impressed but it's different strokes for different folks! Enjoy your rides!
  7. Apr 10, 2017 at 8:21 AM
    DJ TonyT
    DJ TonyT [OP] 2017 TRD 4x4 Off Road DCSB - Sunroof and JBL
    TonyT
    Jacksonville, FL
    My boat and trailer weight right at 3200 lbs.
  8. Apr 10, 2017 at 8:21 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    How do you know?
  9. Apr 10, 2017 at 8:23 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    I looked up the boat and I looked up the trailer weight......
    shakerhood likes this.
  10. Apr 10, 2017 at 8:24 AM
    JoeCOVA
    Joe
    Colorado Springs
    Gotcha, I would have them weighed, I'd bet its a more but 3200 is not terrible.
  11. Apr 10, 2017 at 8:26 AM
    c4lvinnn
    That doesn't seem right. I'm not a boat guy but a simple google search of 19' Mastertcrafts with trailers are 4800+ dry and near 5,500 when filled with fuel and gear.
    bobrown14, Herniator and JoeCOVA like this.
  12. Apr 10, 2017 at 8:45 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Really?????? :eek:
    G.
  13. Apr 10, 2017 at 8:49 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    ^^^^ That bro... then add a few people in the truck and well why towing isn't that much fun.
    Garyji likes this.
  14. Apr 10, 2017 at 8:50 AM
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    Diff Gears?
  15. Apr 10, 2017 at 9:08 AM
    #35
    Garyji
    Gary
    Especially if you don't know what ECT is for.
    G.
  16. Apr 10, 2017 at 9:15 AM
    #36
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    What year and model mastercraft is it?
  17. Apr 10, 2017 at 9:15 AM
    #37
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    I have yet to pull my 20' eliminator more than a half mile with an engine let alone on the highway but that thing is a light weight compared to a mastercraft so take my advice with a grain of salt, but going off the manual use ECT mode to keep the revs up, it pushes the shift points back to keep the engine at peak power like the tow/haul button on other trucks, and use S mode and bump it down to 4th gear, it keeps the truck out of the two overdrive gears. And are you getting for fuel economy number wise and are you towing up hills or flat ground, makes a huge difference.
  18. Apr 10, 2017 at 9:21 AM
    #38
    smitty99
    Scottsdale
    I had a 2005 19 Foot Mastercraft X-7, it weighed in at 2800 dry... so 3400 to 3500 with gas and gear. Trailer was another 700 to 900 pounds.
    You're probably under 5,000lbs. The truck should tow it OK on flat land. It just won't be happy towing it. Your gas mileage will probably be in the 12 to 13 range at best....
    I wouldn't want to tow 5k lbs with this truck more than once or twice a year and never up or down a decent grade.
  19. Apr 10, 2017 at 9:23 AM
    #39
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Guessing it's a single axle trailer. Weight still seems low though. Another note that's dry weight. 30 gallon fuel tank add 240 pounds. Wakeboards, life jackets, that stupid PDF4 floaty they give you a ticket for, food, ice chests, add in the tower because they are not always calculated in the weight, ballast tanks even though they are empty while towing, and people. All of it adds up quick. The 21' Malibu my buddy has is dry weight 3400 pounds off the top of my head, add in tandem trailer 1200 pounds. Post up a pic or model of the boat if you can.
  20. Apr 10, 2017 at 9:49 AM
    #40
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    Fixed it for you.
    Garyji and CanadaToy[QUOTED] like this.
