TRD/Aluminum Battery Hold Downs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coupe, May 31, 2017.
  1. Feb 5, 2020 at 3:22 PM
    #761
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    Would love to buy one for a 2nd gen - 2008 TRD sport Double Cab. Thanks !
  2. Feb 5, 2020 at 3:26 PM
    #762
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    jammer likes this.
  3. Feb 6, 2020 at 4:59 AM
    #763
    Coupe
    Coupe [OP] Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    PM sent.
  4. Mar 9, 2020 at 11:37 AM
    #764
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have some for 1st gen back in stock.
  5. Mar 9, 2020 at 11:50 AM
    #765
    seen20
    seen20 Well-Known Member
    Sean
    2000 3.4 Ext Cab 4x4 5-speed
    Adventure build
    @Coupe I would love a 1st gen one! Not picky on color just whatever is cheapest. Also do you know if these would fit a 3rd gen 4runner?
  6. Mar 9, 2020 at 11:56 AM
    #766
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    PM sent.
  7. Mar 9, 2020 at 12:03 PM
    #767
    vin510
    vin510 Active Member
    Vin
    1995 Toyota Tacoma SR5
    interested for 1st gen.
  8. Mar 9, 2020 at 12:26 PM
    #768
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    PM sent
  9. Mar 9, 2020 at 1:58 PM
    #769
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    does anyone have a part number for a factory hook that's longer than the OEM one? I don't want to use two different SAE bolts to undo my battery. Rather just stick with the two 12mm fasteners if possible. Seen some FJ and Camry J hooks that look longer, but not sure what is best.
    GQ7227 likes this.
  10. Mar 9, 2020 at 2:29 PM
    #770
    GQ7227
    GQ7227 mw survivor
    J A Y
    +2
    +3 for good measure
    the OEM hook on my og 1st gen did not fit into this piece unless the hole was drilled bigger in the back, and then it was not long enough :(
    OCD do i have it
  11. Mar 9, 2020 at 2:29 PM
    #771
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    yep, same exact problem I had. Extra inch or so would do it.
  12. Mar 9, 2020 at 2:31 PM
    #772
    GQ7227
    GQ7227 mw survivor
    J A Y
    is your OEM hook and nut a little blacklish colored? mine is and in a black engine compartment it just looks off without it!
    OCD, OCD i cry!!!
  13. Mar 9, 2020 at 2:37 PM
    #773
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Same, but mainly I just want to use two 12mm fasteners. I don't like any SAE fasteners on my truck, needlessly confusing.
  14. Mar 9, 2020 at 2:43 PM
    #774
    GQ7227
    GQ7227 mw survivor
    J A Y
    i can see your point there if you are removing your battery semi-frequently!
    over 23 years i may have removed mine personally only a couple of times is all
    battery shop did it the other 2 times
  15. Mar 9, 2020 at 3:11 PM
    #775
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    yep, also I won't remember what the hell size to use when I do need to replace. Then I have to mess with different size SAE sockets... no thanks!
  16. Mar 17, 2020 at 1:28 PM
    #776
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have some of these left.
    Textured black with gloss red TRD
    Raw aluminum - no coatings
  17. Mar 17, 2020 at 3:03 PM
    #777
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    These are MUCH nicer than I expected in person. Just received mine a couple days ago. Definitely a nice upgrade.
  18. Mar 17, 2020 at 3:29 PM
    #778
    ryans4x4
    The factory battery bracket did a poor job of holding my battery so much so that last time I took the truck off road the battery came loose and was almost sitting in the fan/belts and I only noticed because the bracket touched one of the posts and arced off it. This new one has little adjusters on the underside of it so you can clamp it to the battery. Very nice! And I shouldn’t have anymore issues with it.
    jammer, mikesdoublecab and Sreppep like this.
  19. Mar 17, 2020 at 7:25 PM
    #779
    techster82
    techster82 New Member
    Clay
    2002 SAS Tacoma Xtra Cab
    SAS with a D44 up Front, Bobbed Bed, Dual Transfer Cases, 37s currently
    I'm interested in a 1st Gen Tacoma setup.
  20. Mar 17, 2020 at 7:35 PM
    #780
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    pm sent.
