TRD Axle Swap Years?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DadsToy, Sep 24, 2009.
  1. Sep 24, 2009 at 4:14 PM
    DadsToy
    DadsToy [OP] Active Member
    David
    Gainesville, Florida
    2001 Tacoma Double Cab 4x4 V6
    Snorkle, ARB Bumper, Warn Winch, Driving Lights, CB, 2 meter Ham,
    I have found some great information on TRD Axle swap with the search.
    Now, tell me which years will bolt into my 2001 Double Cab? Can I use anything from 96-04? What about ABS?
    Assuming I can find a good one, I think I will do this swap instead of the ARB.
    Thanks,
  2. Sep 24, 2009 at 5:46 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    Tacomas actualy have a third member, so thats all you have to swap, but anyway i asked basicly the same question like two days ago so...... I guess nobody has any input?
  3. Sep 24, 2009 at 6:15 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Sep 24, 2009 at 6:16 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
  5. Sep 25, 2009 at 4:22 AM
    DadsToy
    David
    So, does anyone know what years will fit without much modification on my 2001?
    Thanks,
  6. Sep 25, 2009 at 4:57 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    any of them should fit from 95.5 to 04
  7. Sep 25, 2009 at 4:58 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    ^^^^^X2
  8. Sep 25, 2009 at 10:03 AM
    blkcoma32
    Illinois
    Thanks guys!
  9. Sep 25, 2009 at 10:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    What exactly do you plan on doing?
  10. Sep 25, 2009 at 10:17 AM
    blkcoma32
    Illinois
    Well i thought that the third member swaps but i guess i'll have to find a whole axle, I want a locker and don't wanna pay $800 bucks for an ARB, Do u know if the non-trd and trd have the same gear ratio?
  11. Sep 25, 2009 at 10:21 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I am not sure but it is more based on what motor is in the truck. Have you looked into Powertrax?
    Also, there is more to it than just swapping axles for the e-locker. You will have to have a the harness and the plug to hook it into the 4x4 ECU.
  12. Sep 25, 2009 at 10:25 AM
    blkcoma32
    Illinois
    I should just be able to run the wires to some power to the actuator w/ a switch in cab, or am i wrong?
  13. Sep 25, 2009 at 10:26 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That last person that did that go his actuator stuck. I will see if I can find the thread.
  14. Sep 25, 2009 at 10:31 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
