TRD Baja Wheels are true beadlock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmcuajo, Jan 22, 2013.
  1. Apr 17, 2013 at 6:48 PM
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    Most of the dual beadlock (inner and outer) wheels are DOT approved. Such as the H1 military wheels, hutchinson wheels and Stazworks. There are also inflatable bead locks which are DOT approved, http://innerairlock.com
    Bacon
  2. Apr 17, 2013 at 7:25 PM
    Brandon###
    Brandon### Well-Known Member
    As far as the "special lug nuts" , any national tire store such as Discount will stock the conical spline drive lug nuts that are required. They will also have the sockets for sale for around $5.
    I'm not familiar with the balancing issues you're referring to. I have a bronze set on the Taco and the black set on the wife's FJ. Both are balanced every 5k and have over 80k miles between them. We've never had a single balance issue.
    I can see the rings being a balance problem if they had mud caked in them, but if you don't play in mud it shouldn't be a problem. If you do, all you have to do is remove the ring and wipe the mud out.
    2002Tacoma4x4 likes this.
  3. Apr 17, 2013 at 7:28 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    The bronze ones are the ones I'm interested in for my Tacoma. What size tires are you running and what suspension do you have? I think I read you can get away with running 285's with this wheel & modest lifts (2-3") due to the higher offset.
  4. Apr 17, 2013 at 8:23 PM
    Brandon###
    i have 285/75/16s and they do not rub at all
    toytec ulk
    light racing uca's (there's no way around it, you have to buy aftermarket uca's for proper alignment)
  5. Apr 17, 2013 at 8:34 PM
    Ostrichsak
    Jer
    So you're about 3" of lift then or ?
    I'm 5100's with the front set to 1.75" and TSB rear springs for just shy of 2" level/lift front and back. So no UCA's for me and I'm wondering if I can get away with no rub to a little rub that's correctable with slight trimming. Thoughts?
    Do you have some pics? What color is your truck?
  6. Apr 18, 2013 at 12:18 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    well "non-oem" brand, how's that? lol. paint is not my best friend, i tend to steer clear of it when it comes to my truck unless a pro is involved lol. i like those methods, i'm sure once you buy them then powdercoat you are getting close to the price of the oem baja wheels
