TRD Bead Lock Wheels - What to cover holes with?
Discussion in 'Wheels & Tires' started by iJDub, Oct 7, 2013.
  1. Oct 7, 2013 at 9:16 PM
    iJDub
    iJDub [OP] Well-Known Member
    If I decided not to put the rings on the TRD Bead Lock, what should I use to cover the holes? The screws that come with it are too long cause it's meant to be used with ring.
  2. Oct 9, 2013 at 5:16 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    Shorter hex screws or you can also use set screws. I would recommend that you take the wheel into a hardware store and match up the screws that you think will look best.
    Also, it might be a good idea to put a small amount of blue Loctite on the screws to keep them from loosening.
  3. Oct 30, 2013 at 7:48 PM
    Twodog
    Twodog Member
    Todd
    Oroville
    Set screws worked for me 5/16" fine threads 10-24, 1/4" long. Ordered them at a Fastenal cost me 13 cents a piece.
  4. Oct 31, 2013 at 11:47 AM
    iJDub
    Thanks. Wonder if they have black.
  5. Nov 5, 2013 at 5:14 PM
    iJDub
    I think they are M8s?
  6. Nov 6, 2013 at 6:38 AM
    Twodog
    Twodog Member
    Todd
    Oroville
    5/16 and M8 are so close in size that if you get the 5/16 with 10-24 fine threads 1/4" long, they thread in and out with no play and no thread damage. finding set screws in m8 with 1.0 threads is impossible. ill get a pic up of mine in a bit
  7. Nov 6, 2013 at 7:43 AM
    Twodog
    Twodog Member
    Todd
    Oroville
