TRD beadlock wheels are still in production, new part number
Discussion in 'Wheels & Tires' started by RobTacoma22, Dec 5, 2022.
  1. Mar 2, 2023 at 5:18 PM
    #361
    eurowner
    eurowner Duke Sky
    Scoty
    The TACO alloy is a different casting than the Beadlocks.
  2. Mar 2, 2023 at 5:22 PM
    #362
    eurowner
    eurowner Duke Sky
    Scoty
    Beadlocks are 23.5lbs and the new TACO alloy being lighter is a bonus! Two different wheels for sure.
  3. Mar 2, 2023 at 6:20 PM
    #363
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    Just got them installed. FWIW, the tech at America's tire said I could install the rings after he mounts the tires and before he balances them (I brought my torque wrench). He ended up installing the rings for me and even put the enter cap perpendicular with the valve stem. I tipped him for his attention to detail.
    I reused the Goodyear Wrangler A/T tires that came on my OR because I don't want to waste money on a new set yet since I only have 1400 miles on them!
  4. Mar 3, 2023 at 12:10 AM
    #364
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Lol, they’re not bead locks!!! They are cast alloy wheels too. With a fake bead lock ring just the same. I can’t see a difference when comparing pics of the two; nobody else can either unless you maybe really geek out with magnifying glasses. Dude who weighed them said his scale was reading low about 2lbs, so they’re pretty darn close. Maybe someone else can put them on a calibrated scale with rings and bolts installed.
  5. Mar 3, 2023 at 7:11 AM
    #365
    eurowner
    eurowner Duke Sky
    Scoty
    I have know that for 10+ years. Toyota named them TRD Beadlocks.
  6. Mar 3, 2023 at 7:12 AM
    #366
    eurowner
    eurowner Duke Sky
    Scoty
    DCLB FTW:fistbump:
    blackZEBRA[QUOTED] likes this.
  7. Mar 3, 2023 at 7:33 AM
    #367
    blackZEBRA
    California
    '23 TRD OR DCLB
    It was a 2 lb difference between my scale and the doctors scale but that doesn't mean its off by 2 lbs at every reading (0 lb does not equal 2 lbs, 2 lbs does not mean 4 lbs)
  8. Mar 3, 2023 at 8:33 AM
    #368
    TireFire
    Olympic Peninsula
    Alright, glad you were able to clear that up for me :)
    So what IS the ACTUAL difference? For practical and visible purposes?
  9. Mar 3, 2023 at 8:43 AM
    #369
    blackZEBRA
    California
    '23 TRD OR DCLB
    Practical difference is to spread the word to prevent people from paying over $1500 for a used set from 2012 Tacoma TX Baja/ 2015 TRD PRO or 2008-2013 FJ TTE!
    SR-71A and TireFire[QUOTED] like this.
  10. Mar 3, 2023 at 8:49 AM
    #370
    TireFire
    Olympic Peninsula
    Oh for sure!!! I meant the difference between the old and new part numbers tho
  11. Mar 3, 2023 at 8:51 AM
    #371
    blackZEBRA
    California
    '23 TRD OR DCLB
    Thats what I mean. If any, we obviously cant tell by visually looking at it, so its probably an insignificant change for 99% of the people who want these wheels.
    TS4x4 and TireFire[QUOTED] like this.
  12. Mar 13, 2023 at 9:16 PM
    #372
    HighSpeedDirt
    HighSpeedDirt Well-Known Member
    Paul
    Baltimore, MD
    20' Midnight TRD Pro AT
    Performance: Eibach Front Springs Dobinson's Rear Leafs Timbren Rear Bump Stops TRD Air Filter Exterior: ARE CX HD Cap w factory rack/rails Yakima HD Skyrise 3-person RTT AVS Low Profile Front Deflector+In Channel Window Visors Warfab General Sherman Hitch Skid w Recovery Point Ceramic Pro Coating Clear Shield PPF for Front End, Partial Hood, Front Roof, Mirror Backs, Door Cups, A+B+C-Pillars, Rear-Upper Tailgate Interior: DDI Front+Rear Multi Mount Panels on Passenger Seat DDI Billet Quick Release Fire Extinguisher Mount Hondo Garage Phone Mount+Cable Runner Blue Ridge Overland Visor Storage Panel Bed: Rago Fab Bed Rail Accessory Mounts for... Rotopax (4 gallon water+4 gallon gas), 5lb Propane Tank Rago Fab Bed Rail Max Trax Mounts w (4) MTs Hi Lift Bed Rail Mounts w HL 48" Jack Quick Fist Mounts for... Axe, Shovel, Flashlights, Bear Spray, Propane Tank Upper Cargo Net OEM Accessories Installed: Low Profile Side Steps Door Sill Guards Door Edge Guards Mud Guards Bed Extender Bed Mat Bed Lights Bed Step Cab-side Bed Rail Front Bed Lower Tie Downs Electronic Tailgate Lock VIP Alarm with Glass Break Sensor Rear Seat Tablet Holder
    Looks great. Did you swap over your TPMSs as well?
    I am picking up a set of 4 I ordered via the dealer and still need to order center caps. I have the TRD Wheels from 2020 on currently and not sure if the TPMSs will work with these wheels.
  13. Mar 14, 2023 at 8:02 AM
    #373
    eurowner
    eurowner Duke Sky
    Scoty
    If you have the OEM metal body aluminum wheel TPMS sensors, they un-bolt and re-install into the new wheels.
    SR-71A and HighSpeedDirt[QUOTED] like this.
  14. Mar 14, 2023 at 8:58 AM
    #374
    IMissDrugs
    IMissDrugs Well-Known Member
    God I hope so. I just bought 4 new ones from Toyota so I didn't have to dismount the old tires
  15. Mar 14, 2023 at 10:01 AM
    #375
    eurowner
    eurowner Duke Sky
    Scoty
    You still have to break the bead down to remove the old sensors.
    If you have a 3rd Gen and bought 4 new TPMS sensors, you will have to re-program the truck TPMS ecu/pcm, to know and read the 4 new ID sensor numbers.
  16. Mar 14, 2023 at 10:04 AM
    #376
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    That is my absolute pet peeve, when center caps aren't properly installed. That attention to detail is a bonus to an under paid worker. Glad you tipped him and was aware of his service. Love the new rims on your Taco!
    BC Hunter and blackZEBRA[QUOTED] like this.
  17. Mar 14, 2023 at 11:28 AM
    #377
    IMissDrugs
    Nah. I bought new wheels, tires and tpms sensors. I'm leaving the stock set all together so the next person doesn't have to foot the bill when I sell them. Only program them.
    HighSpeedDirt likes this.
  18. Mar 14, 2023 at 8:35 PM
    #378
    blackZEBRA
    California
    '23 TRD OR DCLB
    Yea, swapped over. No issues.
    HighSpeedDirt[QUOTED] likes this.
  19. Mar 23, 2023 at 7:04 PM
    #379
    MGMDesertTaco
    Anyone good with photoshop? I can't decide between grey or black. :annoyed:
  20. Mar 23, 2023 at 7:06 PM
    #380
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Black is a lot for MGM. But I think my SR5 wheels are black rather than grey.
    I bought grey beadlocks but put them on the '02 white Tundra.
    MGMDesertTaco likes this.
