TRD Beadlock wheels with spacers?
Discussion in 'Wheels & Tires' started by Winger12003, Nov 28, 2012.
  1. Nov 28, 2012 at 5:32 PM
    Winger12003
    Winger12003 [OP] Well-Known Member
    Elizabeth City, NC
    2012 TRD OFFROAD 4x4
    265/75/16 Duratracs, 1.25 Spidertrax, OEM rack, TRD catback, weathertechs, TRD bead Locks, 5100's all around with 1 inch rear block
    Found some bronze TRD Fake Beadlocks and was just wondering if any one knows if you can use Spider Trax wheel spacers with this wheel? I have the spacers on my stock wheels right now to allow for more UCA clearance because I am running 275/65/16 Dura Tracs. I would love to be able to use the spacers if I can because I am planning on running 285's in the future on the TRD Beadlocks. I currently am leveled out with 4 Blistein 5100's and a 1 inch rear block.
  2. Nov 28, 2012 at 7:03 PM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    You won't need them, the TRD wheels have less backspacing then stock wheels.
  3. Nov 28, 2012 at 7:07 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    ^^ This. I know many people that are running 285's with no issues.
  4. Nov 29, 2012 at 3:36 AM
    Winger12003
    Elizabeth City, NC
    Thanks for all the replies. Even though I may not need them will the spacers still work with this wheel?
  5. Nov 29, 2012 at 5:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    No, they will make it stick too far out, leading to rubbing on the outside of the tire.
  6. Nov 29, 2012 at 2:06 PM
    Fiveology
    MD
    11 DC TX PRO 4X4
    This^^^^
    I guess since you already have them though you might as well try them, but I seriously doubt you will be able to turn without hitting the fenders. If you have the 1.25" Spidertrax spacers combined with the backspacing of the TRD wheels, it will move the wheel out 2.25" over stock. That is a pretty big difference.
  7. Nov 29, 2012 at 8:01 PM
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    yea man im running 285's on steel wheels with sspidertrax and the rubbed so much i cant imagine pushing them out even more. also runnning billies. id just sell them and recover your money. or chop away
  8. Nov 30, 2012 at 4:36 AM
    Winger12003
    Elizabeth City, NC
    Would I get much rubbing if I decide to keep the 275/65/16's i'm running now? I just like the look of a wider stance, thats why I was wondering about using the spacers.
  9. Nov 30, 2012 at 5:43 AM
    KPT
    09 Prerunner
    Only one way to find out!
  10. Nov 30, 2012 at 3:00 PM
    Winger12003
    Elizabeth City, NC
    Just got in from installing the TRD Wheels and I left the 1.25 spider trax spacers on. I am running 265/75/16 Dura Tracs and the look is amazing. Just enough meat outside the wheel well for a beefer stance and no rubbing. I will post up some pics tomorrow, dark outside now, but I am really happy with the look. May just stay with the 265's instead of the 285's for mileage sake.
  11. Nov 30, 2012 at 4:31 PM
    06sr5prerunner
    luis
    midland tx
    2006 sr5 prerunner
    i havent seen a change in my fuel mileage at all but however im glad it worked for you! post some pics
  12. Dec 1, 2012 at 4:52 AM
    Winger12003
    Elizabeth City, NC
    Here are a few pics of my set-up.
  13. Dec 1, 2012 at 4:11 PM
    06sr5prerunner
    luis
    midland tx
    2006 sr5 prerunner
    i love the wheels man. truck looks good. good job
  14. Dec 2, 2012 at 9:36 AM
    Fiveology
    MD
    11 DC TX PRO 4X4
    Looks good, kinda makes the 265's look bigger then they are.
  15. Dec 3, 2012 at 4:50 AM
    Winger12003
    Elizabeth City, NC
    Drove the truck all weekend with no problems at all, no rubbing issues with the fender flairs outside or inside. The Spider Trax spacers really work well with the TRD Beadlocks to give my truck that wider aggressive stance. They actually make the 265's look bigger than they are, of course it may be the wheels also.:D
  16. Dec 8, 2012 at 11:37 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    Sick!!!! Same tire wheel combo I'm looking for. I want the dark gray beadlocks!!!! What are your front 5100's set at?
  17. Dec 8, 2012 at 11:47 AM
    Winger12003
    Elizabeth City, NC
    Bilsteins are cranked all the way for max lift up front.
  18. Dec 15, 2013 at 4:31 AM
    MrFastener
    MrFastener Fastener Tech
    Richmond VA
    Tacoma Xpro
    3" Toytec Ultimate Adj coil over lift with light racing UCA's, Nittos, remote res rear shocks,
    I have them but dont mistake tire rub for the calipers grabbing the stick on weights. The 16" wheels have like under 1/4" clearance to the rim. Add a stick on weight and some load and when it grabs you would swear it was tire rub.
  19. Dec 16, 2013 at 7:15 AM
    SickNaban
    SickNaban Well-Known Member
    Huntsville, AL
    10 PreRunner SR5 Double
    do you have pics of your spacers on the stock wheels set up? Thinking about putting spacers on mine for the looks as well and wondering what it might look like.
  20. Oct 15, 2016 at 2:25 PM
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    09 PM DCSB TRD OR Pyrite Mica
    Pelfreybilt|Icon|AllPro|SCS|Prinsu
    Bumping this up to see if anyone has spacer with the TRD wheels and 285's. I'm rubbing the upper control arm at full lock quite a bit and want to get an idea of what it looks like.
