TRD Beadlocks + 3RD Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dspec, Nov 8, 2018.
  1. Mar 15, 2021 at 5:50 PM
    #201
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Two more...although with sand and E-loads, they didn't exactly deflate how you'd expect.
    [​IMG]IMG_3949crop by Mike M, on Flickr
    [​IMG]IMG_3914crop2 copy by Mike M, on Flickr
    Fast1[QUOTED], eurowner and The Mink like this.
  2. Mar 15, 2021 at 6:39 PM
    #202
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Looks like you were getting around pretty good.. Sand is defiantly the ultimate environment for low as you can go air pressure and I can see that the E sidewalls are pretty tough. Where were you at in those pics?
    Ran my old std cab down the sand highway on the west perimeter at Glamis a number of years ago.. must have been near 10 psi in the tires and that Taco would hardly get out of its own tracks with the 4 popper.. I've found deep snow can be very similar as soft sand.. need the float with low PSI..
    Thanks for sharing the photos.. Wheels look good on the truck especially in the dirt environment. Are they 8" wide zero offset?
  3. Mar 15, 2021 at 6:53 PM
    #203
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    The photos were taken at Race Point Beach down Cape Cod. I had my 1993 Xtracab down there two years prior. My well-meaning, but mechanically illiterate friend put himself in charge of locking my hubs. Naturally, I went out onto the beach at 10 PM in 2WD and put the back bumper on the sand in sugar sand. I had my KOs down to like 8 PSI before I realized he didn't lock the hubs. Spun them around and all was well. That being said, I pre-emptively put my KOs to 10-11 psi in those photos. I wish I had gone back when the truck was finished for more photos.
    https://parts.toyota.com/p/Toyota__...Style-Wheels---Black/69529039/PTR1835090.html
    I need to get my 2016 down to the beach at some point and see how things go. It was a blast to pull right up next to the water, hop out, pull my beach chair from the bed and sit down.
    Fast1[QUOTED] likes this.
  4. Mar 20, 2021 at 4:35 PM
    #204
    trd4x4boy
    trd4x4boy Well-Known Member
    Fairfax, CA
    2018 TRD Off Road Manual
    I just put 265/75/16 K02’s on a couple of weeks ago w/ no lift and am experiencing rubbing w/ these wheels on full lock if its an off-camber turn/bump. :(
    Going to start researching lift options.
  5. Mar 20, 2021 at 6:57 PM
    #205
    eurowner
    eurowner Duke Sky
    Scoty
    My Toyo Open Country ATII in 265-75-16 do not rub the stock mudflaps, at all.
    tacotoe likes this.
  6. Mar 20, 2021 at 7:11 PM
    #206
    trd4x4boy
    Fairfax, CA
    Nice. No mudflaps on mine but seems to be rubbing just above where the mud flaps would be mounted.
  7. Mar 20, 2021 at 7:32 PM
    #207
    WannaBTacoBro
    WannaBTacoBro Well-Known Member
    No options with a 70 sidewall?
  8. Mar 20, 2021 at 7:39 PM
    #208
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I wonder where you caster is at. I had KOs on my 2013 and KO2s on my 2016 sans-lift and only rubbed very sporadically on hard turns with a bump in reverse. It was never enough to perturb me, though.
    As my KOs wore (maybe 20,000 miles in) I did have a slight tire noise on turn in (like turning from a side street to a main road) I thought was suspension or bearing that turned out to be only tire. I actually pulled my mudflaps post-lift thinking it was a mudflaps.
    Obviously even mild lifting solves th red problem.
    trd4x4boy[QUOTED] likes this.
  9. May 1, 2021 at 11:04 AM
    #209
    WannaBTacoBro
    PXL_20210501_165439987.jpgpowder coated the rings, digging the contrast as the chrome was just a bit too much for me.
  10. May 6, 2021 at 9:03 AM
    #210
    Weidle
    Weidle Member
    2012 Tacoma Regular Cab
    Stock
    Those of you who went with the 285s how much trimming did you need to do? I am looking at getting a 2 inch lift. I already bought some Cooper Discover STT Pros. Just curious how much chopping I am going to have to do.
  11. May 6, 2021 at 10:56 AM
    #211
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    This question will vary according to your castor settings. Those tires are 11.2 wide and 32.99 tall according to coppers website. I'm on just over 2 inches of lift and have the AT3 XLT's in 285. They are 11.6 wide and 32.56 tall. I also have JBA uca's and my castor is at 3 degrees. The only thing I rub on is the upper control arm at full lock. At least that is all I've noticed. I did trim a little by the cab mount and pounded the pinch weld just as a precautionary measure because I plan on moving up to 295's.
  12. May 7, 2021 at 8:37 PM
    #212
    Will_i_s
    Will_i_s New Member
    2019 Tacoma TRD Offroad
    Here's my POS.
    Not a recent pic... Wheels dirty from pollen... I just lifted it today with camburg UCAs. Planning on getting new tires this later this month can't decide o 265s or 285s. I want to get 285s but don't want to run spacers...
    CaptainTikihut, Age315 and miamijime like this.
  13. Jul 16, 2021 at 8:40 PM
    #213
    District Dog
    District Dog DOGS LOVE TRUCKS
    Washington, D.C.
    2017 Quicksand Tacoma TRD Off Road
  14. Aug 20, 2021 at 4:22 PM
    #214
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Hate to bring up an old thread i was looking to get a black or gray set but cant find them anywhere. Anyone have any suggestions?
  15. Aug 20, 2021 at 5:52 PM
    #215
    Will_i_s
    Will_i_s New Member
    They discontinued them best is to keep looking either ebay, Facebook Market, craigslist, here.
  16. Aug 20, 2021 at 5:53 PM
    #216
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Yeah these wheels are basically extinct. Two bronze sets are currently for sale on the forum
  17. Aug 20, 2021 at 6:11 PM
    #217
    The Mink
    The Mink Well-Known Member
    Happyrock, Oregon
    2017 OR AC
  18. Aug 21, 2021 at 7:25 AM
    #218
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Thanks guys appreciate it i will keep digging around
    The Mink likes this.
  19. Aug 22, 2021 at 10:27 AM
    #219
    Will_i_s
    Will_i_s New Member
    YotaFAB likes this.
  20. Aug 22, 2021 at 12:16 PM
    #220
    YotaFAB
    YotaFAB Well-Known Member
    wish these were closer to CA
