TRD Beadlocks + 3RD Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dspec, Nov 8, 2018.
  1. Feb 19, 2023 at 12:38 PM
    #301
    eurowner
    eurowner Duke Sky
    Scoty
    blackZEBRA likes this.
  2. Feb 20, 2023 at 5:22 PM
    #302
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    I miss these so much
    eurowner likes this.
  3. Feb 28, 2023 at 1:01 PM
    #303
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    bringing up this topic again since I just took delivery of new wheels.
    Should I put the ring on before the tire shop swaps my tires on to the new ones or ask if I could install the rings before they balance or install them last? I imagine that the rings are evenly balanced so putting them on post balancing shouldn't cause any problems.
    Thoughts?
  4. Feb 28, 2023 at 1:09 PM
    #304
    Martian__
    Martian__ Well-Known Member
    Southern California
    Do not have the rings on during mounting or dismounting, the pry bar they use will rest in the ring and lightly scuff it. I know from experience. You can also ask the tire shop to remove the rings before any mounting or dismounting but they might decline to work on the wheels.
    In short, if you don’t want scratches or scuffs, take them off before any tire work.
    blackZEBRA[QUOTED] likes this.
  5. Feb 28, 2023 at 1:12 PM
    #305
    blackZEBRA
    California
    '23 TRD OR DCLB
    Should they be on for balancing or is it fine to put them on once I get home? It might take up too much of their time if I ask to install the rings in between.
  6. Feb 28, 2023 at 1:18 PM
    #306
    Martian__
    Southern California
    Personally I would get them rebalanced after you reinstall the rings.
    Wheel weights go by ounces or grams, it’s very minimal but any change to the weight will cause a vibration, even if it’s minimal at high speeds.
    You’re essentially throwing off the weight if you get them balanced without the rings and hardware because you’ll be adding weight to one side of the wheel and they are dynamic balanced.
    Fast1 and blackZEBRA[QUOTED] like this.
  7. Mar 2, 2023 at 6:22 PM
    #307
    blackZEBRA
    California
    '23 TRD OR DCLB
    The worker at America's tire installed the rings for me and torqued them using my torque wrench because they don't have a 3/8" that did inch pounds or a 1/2 that did 6 ft/lb.
    He even knew to put the cap's on perpendicular to the valve stem!
    kona61, BC Hunter, eurowner and 3 others like this.
  8. Mar 2, 2023 at 6:38 PM
    #308
    blackZEBRA
    California
    '23 TRD OR DCLB
    eurowner[QUOTED] and daveeasa like this.
  9. Mar 2, 2023 at 7:19 PM
    #309
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    The question is did he put the lock in the same location on each wheel? I put mine on the bottom "D" side. I love me some good attention to detail.
  10. Mar 2, 2023 at 7:19 PM
    #310
    blackZEBRA
    California
    '23 TRD OR DCLB
    It looks like the locks might be at the "T" but I'll check tomorrow lol
    MikeyMcFly[QUOTED] likes this.
  11. Mar 2, 2023 at 7:23 PM
    #311
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    The "T" is fine by me. It's the people that just splay them all over the wheels that need their head examined!
    Best looking wheels you can fit to these trucks, hands down.
  12. Mar 2, 2023 at 7:31 PM
    #312
    blackZEBRA
    California
    '23 TRD OR DCLB
    I like that they are OEM wheels but makes the truck look slightly modified but not screaming "hey look at me bro"
  13. Mar 3, 2023 at 12:09 AM
    #313
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    :101010:
  14. Mar 3, 2023 at 7:35 AM
    #314
    blackZEBRA
    California
    '23 TRD OR DCLB
    Just checked, they are NOT all at the "T". I'm going to pretend putting the lock at the same location on all four wheels is a thing lol
  15. Mar 19, 2023 at 3:11 PM
    #315
    HIKEOUT
    HIKEOUT Well-Known Member
    VA
    13 BLACK DC BAJA
    Does anyone know the weight of these rims? Thanks!
  16. Mar 19, 2023 at 3:55 PM
    #316
    MGMDesertTaco
  17. Mar 19, 2023 at 4:08 PM
    #317
    HIKEOUT
    VA
    13 BLACK DC BAJA
    Thanks!
    MGMDesertTaco likes this.
  18. Apr 5, 2023 at 11:30 AM
    #318
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    These look good, and also just introduced way too much indecision into my life on black or gunmetal.
    Vjustinc likes this.
  19. Apr 5, 2023 at 4:01 PM
    #319
    Vjustinc
    Vjustinc Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    Looks great! Are the black rings diy?
  20. Dec 2, 2023 at 12:03 AM
    #320
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    Lunar Rock on black TRD Beadlocks with black center caps
    Haymaker, Btac16, Fireme and 4 others like this.
