TRD Beadlocks + 3RD Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dspec, Nov 8, 2018.
  1. Mar 3, 2020 at 8:22 PM
    #101
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Someone mentioned above that they did, I have never rebalanced after removing and installing. They self center, and any movement based on tolerances before they are tightened is negligible.
  2. Mar 3, 2020 at 8:22 PM
    #102
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
  3. Mar 3, 2020 at 8:32 PM
    #103
    The Mink
    The Mink Well-Known Member
    Happyrock, Oregon
    2017 OR AC
    No balancing issues with mine in 1.5 years since I had them mounted without rings and installing after.
  4. Mar 3, 2020 at 8:34 PM
    #104
    The Mink
    Happyrock, Oregon
    2017 OR AC
    Looks great with the army green :thumbsup:
  5. Mar 3, 2020 at 8:54 PM
    #105
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    Thanks for the photo.
  6. Mar 3, 2020 at 10:54 PM
    #106
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    My two Cents worth based on personal experience is that I had my wheels balanced with ring on and when I removed them to have them powder coated they vibrated and was out of balance with feed back to the steering wheel. I wasn't severe but enough to notice. About a week later I had them reinstalled and all back to normal. Your experience may vary.
    1992SR5V6 likes this.
  7. Mar 4, 2020 at 6:26 PM
    #107
    Bradg93
    Bradg93 Well-Known Member
    Port Hope, Ontario, Canada
    2020 TRD Sport DCLB Cement Grey
    Exactly my plan
  8. Mar 5, 2020 at 10:40 AM
    #108
    Bradg93
    still Wondering if anyone has these with like a highway tire. I’m getting Michelin defender ltx m/s and want to make sure that they won’t look funny
    also the Toyota website says “tires may experience more wear than with usual rims” why?
  9. Mar 5, 2020 at 4:53 PM
    #109
    1992SR5V6
    1992SR5V6 Well-Known Member
    2018 TRD Sport 4x4 Cement
    Bolt on only...
    Finally! I got my TRD Bronze Beadlocks with Satin Black rings and 265/75R16 Goodyear Ultraterrain AT tires installed. Discount Tire was excellent, they got the 5th tire for the spare in next day, and let me come in the shop and installed the rings between mounting and balancing. Super happy with the new setup!
  10. May 23, 2020 at 9:07 AM
    #110
    DTaco22
    DTaco22 Well-Known Member
    Darian
    17' Taco. TRD OR
    3" Eibach lift, JBA high caster upper control arms, 2" ToyTec add-a-leaf
    Is anyone running these with a 2"-3" lift and 285/75/16 WITHOUT wheel spacers? And using stock upper control arms?
  11. May 23, 2020 at 9:30 AM
    #111
    DTaco22
    Darian
    17' Taco. TRD OR
    Are you running stock UCAs and wheel spacers?
  12. May 23, 2020 at 10:38 AM
    #112
    SFV_TacoTruck
    SFV_TacoTruck Active Member
    San Fernando Valley, Los Angeles
    2017 Tacoma TRD Sport
    Pro Comp leveling kit (3" FRONT, 1" BACK) [sku: 65205k] Toyota TRD Beadlock Rims (16" x 7.5, +10mm Offset) Nitto Ridge Grapplers LT285/75R16
    I am running 285/75R16 WITHOUT wheel spacers and stock upper control arms. I have a Proc Comp leveling kit (3" front 1" back)
  13. May 23, 2020 at 10:43 AM
    #113
    DTaco22
    Darian
    17' Taco. TRD OR
    How far away are you from your UCA?
  14. May 23, 2020 at 10:44 AM
    #114
    DTaco22
    Darian
    17' Taco. TRD OR
    Also, do you rub on your frame or body mount?
  15. May 23, 2020 at 6:16 PM
    #115
    Yellowplatypuss
    Yellowplatypuss Well-Known Member
    Columbia, SC
    2016 TRD Off Road
    Bilstein 5100 OME 888 & 5160 with AAL, SCS F5, Yokohama GEOLANDERS, morimoto hid and led fogs. Clazzio leather seat covers, ECGS bushing, TRD PRO Grill, Hondo Mount, Martin rack, Baja designs. Caliraised, Ov Tuned
    in this picture no spacers and stock UCA
  16. May 23, 2020 at 6:40 PM
    #116
    SFV_TacoTruck
    It's pretty tight. I got less than 1" clearance from the tire sidewall to the UCA. I do rub from time to time, if i hit a bump at a pretty high speed. If you don't do serious off roading/ rock crawling, a leveling kit is good enough, otherwise I'd suggest modifying the suspension with an actual lift kit.
    I'm just going to wait until the stock suspension goes to upgrade it on mine with an actual lift. My next mod is probably spydertrax wheel spacers (maybe 1.25") to give it a wider stance. These beadlocks run a +10mm offset, so you don't really get that "poke" out the fenders
  17. Jun 18, 2020 at 9:47 PM
    #117
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    20200614_161021.jpg A teaser of what's in the works.
  18. Jun 19, 2020 at 7:40 AM
    #118
    SFV_TacoTruck
    Did you powder coat the rim and ring? Looks great, lately I've been considering powder coating my beadlocks graphite. When I originally started looking to purchase I was on the fence between the black and graphite and I went with the blacks. But now I have been thinking about getting them coated a graphite/metallic color
  19. Jun 19, 2020 at 12:05 PM
    #119
    Age315
    AJ
    Castle Rock, CO
    I just spray painted them with rustoleum matte soft iron. It's a little darker than the graphite color but I like it. Thought about having them powder coated but when they get scratched this is easier and cheaper to touch up. I also bought some black bolts but they are black oxide which will rust so I'm still trying to figure out what to do. The pic has half stock bolts and half black bolts for reference. Screenshot_20200619-130242_Firefox.jpg
    MGMDesertTaco and SeaDweller3T like this.
  20. Jun 30, 2020 at 7:53 AM
    #120
    Age315
    AJ
    Castle Rock, CO
    I'm just going to drop this here. It's the install instructions for the bead lock wheels. I found it looking for the torque spec for the rings. It's 75 inch lbs or 6.25 ftlbs for anyone who has OCD.
