TRD blower with IMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Jan 15, 2015.
  1. Jan 15, 2015 at 10:19 PM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I want to get a TRD blower this year and I have an intake manifold spacer and was wondering if I can run both together. The IMS Iis not installed yet but I'm thinking of installing it next month and getting the blower around summer. What are your thoughts?
  2. Jan 16, 2015 at 7:31 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Why would you do that? The IMS reduces power, don't use it. It is snake oil and a complete waste of money. I know, because I had one myself many years ago. Luckily I sold it used and at least got some money back out of it. Why TRD? Have you checked these out yet? http://urdusa.com/store/Forced-Indu....html?osCsid=e5fe86c446fc0a6754cfb494cfdda913
  3. Jan 16, 2015 at 11:28 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I read in a post that the IMS will cause clearance issues with the trd blower install. Its been mentioned in one of the threads in TW.
  4. Jan 16, 2015 at 2:09 PM
    1tacoplease
    Temecula
    Do you guys think I can install the IMS and take it off when I go supercharged?
  5. Jan 16, 2015 at 2:10 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yes, but again you will actually LOSE power if you put it on.
  6. Jan 16, 2015 at 2:11 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    You could do that. As with already been said the spacers do very little. On the old carburetor motors they helped but do very little on newer stuff. Waste of time and money.
  7. Jan 16, 2015 at 2:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    where is your proof for that.
    An intake manifold spacer like XTP's creates longer intake runners by being placed between the upper and lower intake. This creates more midrange, it was quite noticeable on my truck when i installed it.
    That stated throttle body spacers are pointless in this day and age of port injection / direct injection.
  8. Jan 16, 2015 at 2:16 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The intake manifold spacer will cost HP?
    I'd expect that from a throttle body spacer, but not the ims.
    Bummer
  9. Jan 16, 2015 at 2:18 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Just to be clear your asking about an intake manifold spacer not a throttle body spacer?
    You would need a longer belt to run the ims..its been discussed before in another thread if I can find it. You would be raising the supercharger
  10. Jan 16, 2015 at 2:55 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    The IMS actually gives you a nice boost in torque and power at low rpms. I noticed it, went wheeling with 33s same hill before and after. Saw the boost while crawling truck was less hesitant.
    You will loose mpg with it, tho I have found that if you run 89 or better on highway and or while towing it brings it back up to mpg levels before installing IMS.
    It be impossible to use with a blower you loose all alignments and belts would be wrong length. it is a good inbetween, going to hopefully go blower later this year if funds remain!
  11. Jan 17, 2015 at 10:50 AM
    1tacoplease
    Temecula
    I just learned that with a TRD blower, you have to change the spark plugs every 30k and that it's not an easy feat because it involves removing the supercharger. Have any of you experienced this and what are your thoughts?
    I'm also lacking in the torque department. That's why I am thinking about the Intake Manifold Spacer (which I Already have) to gain some lower end power.
  12. Jan 17, 2015 at 10:52 AM
    nd4spdbh
    SoCal
    I'm pretty darn sure you don't have to remove the super, I'll look on my buddies truck next time I see him.
  13. Jan 17, 2015 at 10:54 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    90k like lobster said...... Use swivels and the right extensions and there's no need to pull the blower.
  14. Jan 17, 2015 at 12:16 PM
    1tacoplease
    Temecula
    I'm currently running Denso IKH20 spark plugs right now. I believe those are iridium. Please correct me if I'm wrong.
  15. Jan 18, 2015 at 10:49 AM
    1tacoplease
    Temecula
    Can anyone else confirm that I would lose power if I install an INTAKE MANIFOLD SPACER? I'm looking for a little more around low to midrange power.
  16. Jan 18, 2015 at 11:03 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Same here. I've seen the dyno results, it does move the power band lower so you'll get more low end and mid end power.
    To OP if you plan to run the TRD SC I wouldn't bother with the IMS. I'd get the smaller pulley like a 2.85" if you want more power.
  17. Jan 18, 2015 at 12:04 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    ...At the cost of peak HP. Personally I strongly believe this dyno to be BS, but there it is. http://extremetruckperformance.com/?page_id=300
  18. Jan 18, 2015 at 4:25 PM
    Lord Helmet
    Nick
    Correct I would like to see more dyno results to see different variations. I'm not a big fan of the mustang dyno either.
  19. Jan 19, 2015 at 12:23 PM
    1tacoplease
    Temecula
    Thanks for the dyno's. I the TRD blower is out of my league. Found one for $4485 and dealer would charge me $1440 to install. Thinking about doing a pre and post IMS install dyno myself. Let me check pricing on that.
