TRD Boost Gauge Calibration?
Discussion in 'Performance and Tuning' started by SManZ, Jul 6, 2010.
  1. Jul 6, 2010 at 4:14 PM
    SManZ
    SManZ [OP] el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Is it possible to calibrate or adjust the face on the TRD boost gauge? Its essentially an Autometer mechanical boost gauge. At rest, it reads a half tick below 0 and I'd like to get the needle centered.
    There's two screws on the back but I'm hesitant to open it up without knowing what the guts look like.
    -Thanks!
  2. Jul 7, 2010 at 6:07 PM
    GodHatesUsAll
    GodHatesUsAll Reign in Blood
    Satan
    Six Feet Under
    05' Black Sand Pearl XRunner
    TRD Blower//APR X-1//668cc Primaries & 7th inj//URD 2.8"&NST OD Pulleys//AFE StageII Si CAI//URD Fuel Pump//JBA GenII lT's//URD S/S//URD Lite Flywheel//Competition Clutch StageIII//NST Lite Pulleys//Sittin Sic Front coils/Rear Mono leafs//
    Damn I'm about to buy one used and I noticed it reads -1 when off. I'm wondering the same thing? Can it be adjusted or is it phucked?
  3. Jul 7, 2010 at 6:18 PM
    SManZ
    Haymarket, VA
    If no one chimes in here I'll probably take the dive and try it. I'm OCD like that about little things like this. The boost gauge appears accurate. When I count in the half point that its off, it reads 6psi which is exactly what the TRD S/C is supposed to be outputting.
  4. Jul 7, 2010 at 6:23 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    pressure gauges are usually a bourdon-tube- there may be an adjustment screw to zero it out as there is on a regular bourdon-tube pressure gauge.
  5. Jul 7, 2010 at 6:28 PM
    SManZ
    Haymarket, VA
    Thanks Bradley! This definitely looks like something I want to be careful not to muck up. I don't think there'll be any harm in unscrewing it and removing the case to take a peek.
  6. Jul 7, 2010 at 7:24 PM
    GodHatesUsAll
    Satan
    Six Feet Under
    Let me know what happens. I currently have a digital boost gauge in my truck and can keep it installed to see if the TRD one is accurate or not. I know my vac is 18-20 at idle and I know my peak boost is 8psi. These gauges are rare and I may just take the plunge.
  7. Jul 8, 2010 at 3:29 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You're welcome! It's ancient, dirt-simple technology, I would just avoid touching the actual tube in fear of bending it.
  8. Jul 8, 2010 at 3:41 PM
    Firetech
    Firetech Well-Known Member
    Ralph
    Maryland
    2010 SR5 Off Road
    If you don't have a calibrated guage to compare it with don't try to adjust it. Guages are tested up and down the scale. if it is off the same margin it may be adjustable. if not they need to be replaced.
  9. Jul 8, 2010 at 5:05 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Thats how the gauge is. I had a white in my 04 and black faced in my 07 and they were both like that. If you tap on the face with your finger it will go to zero.
