TRD boost gauge replacement hose
Discussion in 'Performance and Tuning' started by BackwoodsTaco, May 29, 2014.
  1. May 29, 2014 at 5:39 PM
    BackwoodsTaco
    BackwoodsTaco [OP] Well-Known Member
    Paul
    Stokes, NC (Eastern NC)
    Radiant Red 01 DC, 4X4, SR5, Supercharged
    TRD Supercharger, URD 7th injector kit, TRS RetroFit, Deck Plate Mod, No Chime Mod, Fog Light Mod, CB/ashtray Mod, 2.5" Spacer Lift, 1.25" Lift Shackles, 4 Tab Light Bar From Eddie209
    I just got a brand new TRD supercharger and I was lucky enough to find a TRD boost guage so cheap you wouldn't believe it :D Now my question is the gauge didn't come with the hose to connect it to the supercharger. So where can I get a replacement?
  2. May 29, 2014 at 7:16 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  3. May 30, 2014 at 6:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Silicone hose. Super easy.
