TRD Brake Pads... anyone?
Discussion in 'Performance and Tuning' started by ThatguyJZ, May 9, 2015.
  1. May 9, 2015 at 4:55 AM
    ThatguyJZ
    ThatguyJZ [OP] Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Is anyone running TRD brake pads on their truck? Any thoughts on their performance and your overall satisfaction? Also, does anyone know who makes the pads for TRD?
    I refuse to run Hawk's - I owned two sets on two difference vehicles, including LTS pads on my old ZR2 and had nothing but problems from the backing plates separating from the pads. Outside of the TRD pads there doesn't appear to be much else in terms of a performance level pad.
    Thanks!
  2. May 9, 2015 at 6:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    TRD, EBC, Stop Tech, Carbo Tech, Hawk (which you don't like).
    TRD pads work quite well. They dust like a son of a gun though. Try www.trdparts4u.com. They might have some in stock.
    They might be made by Stop Tech, but I don't remember.
  3. May 13, 2015 at 7:16 AM
    ThatguyJZ
    Jim
    TRIAD, NC
    Thanks!
  4. Jun 7, 2015 at 9:05 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    just notice this thread. I ordered a set of trd pads off ebay for about 90bucks. They do work pretty good, a bit better then stock. The huge downside is these pads dust like crazy, so if you're a clean freak these pads are not for you.
  5. Jun 8, 2015 at 8:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Very dusty
  6. Jun 8, 2015 at 12:18 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    They are a good all rounder and are very well priced imo.
    Torspd likes this.
