TRD CAI Filter Replacement vs Cleaning
Discussion in 'Performance and Tuning' started by cdn_bacon, Apr 2, 2013.
  1. Apr 2, 2013 at 8:11 AM
    cdn_bacon
    cdn_bacon [OP] Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    I'm at the 60k mark and I've decided to do as much of the maintenance on the truck myself as I can. One of the things I really need to do is either replace or clean the TRD CAI filter. After researching a bit I came across several options but first I should add the caveat that I put the TRD filter in the CAI dry which I'm not sure if I was suppose to do or not so I can only imagine how dirty it is and how its been affecting my MPG.
    Options:
    Clean and oil the existing TRD CAI filter?
    Replace with stock new TRD CAI filter - $55 + ship
    http://www.onlinetoyotaparts.com/oemparts/toyota-155/P/PTR0535066.html
    Replace with AFE filter which you can get either a dry or wet model.
    aFe P/N 24-91021 around $70.
    So what should I do here? I guess it makes sense to get a TRD CAI filter replacement since I found one in stock and its cheaper than the AFE filter. Does this need to be oiled? :cool:
    oh... if anyone knows where to get a cheap AC cabin filter too please post it up. Thanks.
  2. Apr 2, 2013 at 12:29 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Replace with afe pro dry S
    I buy my cabin filters from the dealership.....they beat napa and kragens price, same with oil filters
    Btw, trd doesn't make filters.................. so don't worry about "trd" matching products.....toyota has K&N, or AFE make their "trd" gauze air filters
  3. Apr 2, 2013 at 3:26 PM
    cdn_bacon
    Christopher
    Houston
    I thought I read somewhere that the pro dry doesn't last as long as a wet filter. Is that true?
    Recommend anywhere to get a Pro dry for a decent price? It's more than buying a replacement filter from the stealership.
  4. Apr 2, 2013 at 4:00 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I honestly don't know what u mean about lasting as long...........
    Dry filter will be better for MAF sensor.
    As for the afe dry, try Amazon, gadget at urdusa.com, orbuy/sell/trade area
    Running an amsoil right now with the urd, but I had the afe at 1 point years ago and it seemed fine.
    Ymmv............certain climates/driving conditions may not be good for a dry filter and stock would be safer.....again, ymmv
  5. Apr 8, 2013 at 7:32 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
  6. Jun 21, 2013 at 2:38 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Slight bump.. :D
    Similar question here. Anyone know if there is a dry replacement for the 2nd gen TRD. It uses a flat oiled filter.
  7. Jul 4, 2013 at 7:13 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Similar question, how long do you guys usually go before replacing a reusable filter?
    I've got 85,000 miles on the TRD CAI with its original filter. Due for another cleaning. Not sure if I should just clean it again or replace. The tube behind the filter is spotless so I guess the filter is still doing its job just fine.
    I've been using K&N cleaning/oil kit every 15-20k miles.
  8. Jul 4, 2013 at 7:22 PM
    Calidrifter
    Calidrifter New Member
    SoCal
    05 TRD Off Road PreRunner SR5 V6
    Every 3rd or 4th oil change is fine to clean the filter as that's usually when you are supposed to change the filter anyway.
    In regards to the question on longevity of the pro dry vs oiled. The oiled version is meant to last longer as it is reusable. The dry is meant to be replaced every 15-20k miles.
