TRD CAI intake arrives today, install advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raskal311, May 13, 2011.
  1. May 15, 2011 at 8:56 PM
    raskal311
    raskal311 [OP] Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    It sounds good at fot and not much with normal driving which is perfect. I have one last question, is the filter pre oiled? The direction saids nothing about oiling other then during the next cleaning. Btw I put about 100 miles on the truck today and no issues other then the ac taking alot longer then normal to get cold. Any thoughts on this? I figured it was because I moved the ac line during install.
  2. May 15, 2011 at 9:04 PM
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    Should be oiled...Did you kink the line?
  3. May 15, 2011 at 9:08 PM
    raskal311
    S. Cal
    Should be as in needs to be or should already be? Not sure a out the line I'll have to check tomorrow.
  4. May 15, 2011 at 9:12 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Should be pre oiled from the factory. It didn't say anything on the box or anything? Website?
  5. May 15, 2011 at 9:27 PM
    raskal311
    S. Cal
    Read the entire direction and didn't see anything. I
    Also google it and only found stuff on cleaning/oiling
