TRD CAI Question
Discussion in 'Performance and Tuning' started by erock, Jan 29, 2008.
  1. Jan 29, 2008 at 1:53 PM
    erock
    erock [OP] Well-Known Member
    Boise
    06 TRD OR Tint Window, Magna Flow 2.5 Catback, TRD CAI, 3" Revtek and TSB, 33" Toyo MTs
    Cig Lighter Will tackle the Rear Locker Always On soon
    I have the TRD Cold Air system installed. Will popping the lid off the box give me more air for the filter or just expose it to more particles? Right now it's entirely sealed in except for the air it draws from the hole in the firewall thaqt seems to come up from the front tire well. I'm looking for maximum efficiency and hp. Thanks for any responses.
  2. Jan 29, 2008 at 3:35 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if u take the lid off, ur gonna be exposing it to draw in hot air from inside the engine compartment. so not only dirtier, but hotter as well
  3. Jan 29, 2008 at 8:43 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    ^ +1 Would defeat the whole purpose.
  4. Jan 29, 2008 at 9:03 PM
    erock
    Boise
    But how is that different from other CIA systems that all seem to have an open compartment housing? Like the K & N and Airade which I have seen on many members taco descriptions. That's where I got the question in the first place...It seems that most other CAI's draw from the air coming in from the front. Though I know that the Taco's sits on the side wheel well. Yet theirs must work to some degree.
  5. Jan 29, 2008 at 9:11 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    what makes you think any air is coming in from the front? If you look at the grill area and what not, it's pretty well blocked off. Just because aftermarket ones are how you described them, doesn't mean they really work to any good degree. No intake will work wonders regardless, but i can guarantee TRD's is like that for a reason. I wouldn't alter how it comes.
  6. Jan 29, 2008 at 9:20 PM
    silvertaco408
    silvertaco408 Well-Known Member
    San Diego, CA
    17 double cab long bed 4x4 trd off road
    Pioneer Avic Z2 navigation with ipod and bluetooth, K&N 77 Series intake, DT Headers, Flowmaster 50 exhaust, All Weather Mats, Fog Light Mod, Debadged, 20% tint all around, custom blue dome, maps, steering wheel, shifter lights, and cluster, Midland CB with PA, XD Series Revolvers wrapped in BFG AT's, black mesh grillcraft grill
    I know that my K&N 77 intake has a tubing around the top of the casing around the filter that seals with the hood. So the filter is enclosed when the hood is shut. The trd one is in the box so it is enclosed all the time... wouldnt take the top off is I was you because it would just expose it more to particles. Just my guess though.
  7. Jan 31, 2008 at 8:59 AM
    erock
    Boise
    From my understanding the whole point of the "Cold Air Intake" was to take air in from the front, unless of course there is an alternative access point like the Tacoma's firewall.
    That would make more sense to me that the hood seals the top of the other aftermarket filters. So, I guess the lid stays on :)
  8. Jan 31, 2008 at 9:31 AM
    MaGuyver
    MaGuyver Well-Known Member
    Savannah, Ga.
    2020 Tacoma Sport, Cement
    Tinted glass, Bed mat, Rigid light bar, Bakflip FiberMax tonneau, Bull bar, LED cabin lights, Bed lights.
    Could you put a hole in the side or back and run tubing (of some type) from the front grill to the box? Like a deck plate mod but smaller and with a hose/tube.
  9. Jan 31, 2008 at 2:59 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I was thinking something like this as well....either routing a tube to the grill itself, or perhaps getting a hood with a scoop and cutting and making an intake from a functioning hood scoop. That would provide pretty friggin cold air!
  10. Jan 31, 2008 at 3:11 PM
    MaGuyver
    Savannah, Ga.
    Beware of vapor lock. Plus a scoop would suck more bugs and dirt. You would have to clean it more. But, I do like a working scoop. If I put a tube to the front I would angle it down so the water, bug, dirt problem would be as bad.
