TRD CAI/TRD EXHAUST will it add HP?
Discussion in 'Performance and Tuning' started by deggystaco, Apr 26, 2014.
  1. Apr 26, 2014 at 8:31 PM
    deggystaco
    deggystaco [OP] New Member
    Kelowna BC Can
    2009 Tacoma sport 4x4
    Levelling kit and 33"tires
    I have a 2009 tacoma with a leveling kit and 285/75 R16 tires. Everything else is stock. I want to add some HP but don't want to sacrifice a lot of MPG. I know a turbo is an expensive option but I am more interested in a CAI and an exhaust system that will work together with it. Anyone have any success with adding horse power with a CAI and exhaust system? Which systems would you recommend. Does a TRD after market system exist?
    My driving style uses lower RPMS as I don't have a lead foot. I often drive with low load not hauling at all. I just want my truck to perform better as it can struggle to turn those tires on hills. I'm sure i'm not the only one with this problem. Any solutions?
  2. Apr 26, 2014 at 10:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Re gearing to 4.10's will give the best performance gain, and return lost mpg.
  3. Apr 28, 2014 at 6:23 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There are few bolt-ons that will give you much of anything at low rpms. Engine is about as efficient as it can get at anything <3500 rpm, some gains on some items at 3500+. Short-tube headers are probably the closest thing, but between the header costs and cost to weld the cats back on, not a cheap alternative. Only other thing I've seen that claims to increase low-end is an intake manifold spacer, but the data on that is still questionable IMO, although it does get positive seat of the pants reviews. Gears can help, as mentioned, but come at a cost of highway milage.
  4. Jun 23, 2014 at 11:13 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    For low end just swap out the muffler with stock exhaust, I went with a 18" round(not too loud but you hear it), I did a 2 1/2" exhaust and lost some low end power.
    Change the air filter and do the intake spacer...
    you will pick up a lot of power....
  5. Jun 23, 2014 at 11:15 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    How bad? *raises one eyebrow*
  6. Jun 23, 2014 at 11:17 PM
    skynet
    skynet Well-Known Member
    San Diego
    13 TRD Sport
    Scattered 12g shotgun shells in the bed to deter tweekers from stealing my stereo
    fastest and cheapest way for more power is Nitrous Oxside, but far from recommended. CAI and exhaust alone will do very little to increase more HP But swap out your cam and reprogram you ecu and youve made some power!!!! or just SC the thing.
  7. Jun 24, 2014 at 11:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If he swaps out just one cam, it might not have the intended desired effect. ;)
  8. Jun 24, 2014 at 1:24 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    and reprogram an ECU that can't be reprogrammed.
  9. Jun 24, 2014 at 1:28 PM
    Vassily28
    AFE CAI stage 2 SI with ProDry S air filter
  10. Jun 24, 2014 at 6:19 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Intake manifold spacers move the tq curve down a bit in rpms but that means sacrice in upper rpms. There is a group buy somewhere around here i think for around $200
  11. Jun 24, 2014 at 6:21 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
