TRD Cat Back-- Things to note...
Discussion in 'Performance and Tuning' started by j4x4ar3, Mar 11, 2008.
  1. Nov 20, 2020 at 2:53 PM
    Bootselectric
    Bootselectric Well-Known Member
    Stirling
    2004 PreRunner (RIP) 2013 TRD Sport (DCSB-BRM)
    Good to know, and much appreciated!!
  2. Nov 20, 2020 at 2:56 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    its cause the aclb is the same wheelbase as the dcsb so it shares the same exhaust
    Bootselectric[QUOTED] likes this.
  3. Nov 20, 2020 at 4:58 PM
    Bootselectric
    Stirling
    Out of curiosity, did you replace the gasket (17451-0A010), if not, do feel this may have added to the accentuated drone sound?
  4. Nov 20, 2020 at 5:50 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    No....my rig was only a few weeks old when I through on the TRD. The gasket was basically new. And no....the drone is just the nature of an even-fire, 60° V6 engine. The exhaust pulses are very close together, making it naturally a bit buzzy. A 90° odd-fire V6 would sound better but you would give up refinement, as a 60° V6 is inherently better balanced than a 90° V6.
    At the end of the day, sound quality is subjective. And at idle and above 4000 rpm, it sounds great. Unfortunately it sounds it's worst in between those areas.....where you spend 90% of your time. And the highway drone is maddening.
    But that's only my opinion
  5. Nov 24, 2020 at 3:47 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    This is literally what I needed to read. Thank you Plain Jane! I put this on and was wondering if I needed a new gasket to lessen the drone between idle and above 4,000 rpm. It's not a bad sound output by any means, but I think the notes that the TRD produces on the FJ (perhaps a 90° odd-fire V6?) is ideal.
  6. Dec 4, 2020 at 6:01 PM
    King Kermit V
    King Kermit V Well-Known Member
    Kermit
    Miami, FL
    2018 Black Tacoma SR5 DCSB
    Taco sauce
    I tried the link but it’s broken. I could buy the domain though.
