TRD Catback Exhaust Stock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dropitmore, Feb 25, 2015.
  1. Feb 25, 2015 at 12:25 PM
    Dropitmore
    Dropitmore [OP] Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    Hi,
    I apologize for the stupid question in advance but I feel I've exhausted my search efforts.
    Does anyone know if the 2013 TRD Sport DCLB comes with a TRD catback exhaust from factory? Or will I need to purchase separately?
  2. Feb 25, 2015 at 12:26 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Purchase separately. Unless it's already added.
  3. Feb 25, 2015 at 12:50 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And then your truck will sound awesome like mine.
    Oh wait, you'll need another toy for totally awesome sound.
  4. Feb 25, 2015 at 1:17 PM
    Dropitmore
    Andy
    Downey, CA
    ok thanks for the clarification, didnt want to make the mistake of purchasing it, if it already came stock lol.
    Thanks
    Andy
  5. Feb 25, 2015 at 1:18 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Where are you buying one from?
  6. Feb 25, 2015 at 1:20 PM
    Dropitmore
    Andy
    Downey, CA
    Thats my next step lol Haven't started researching the various vendors just yet. Any recommendations?
  7. Feb 25, 2015 at 1:20 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Your 13 already has a good mandrel bent 2.5 exhaust from the cat back. All that $4-500 will buy you is the muffler. Just get a muffler welded in and pocket the difference. Unless you think you need a 3" exhaust, its a bit of a waste of $$$.
  8. Feb 25, 2015 at 1:22 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Well if you do decide to go the TRD route I can get you one for 375.00 shipped. Unless you are in Canada. It does not state where you are in your avatar
  9. Feb 25, 2015 at 1:24 PM
    ThomasMore66
  10. Feb 25, 2015 at 1:26 PM
    Dropitmore
    Andy
    Downey, CA
    Gotcha, good to know. Im open to researching the perfect muffler, im not stuck on the TRD catback. I just hate to get stuck with one that drones all through the cab.
    Ill search through the archives to get a better idea of what sounds the cleanest.
    Thanks for the heads up
  11. Feb 25, 2015 at 1:28 PM
    Dropitmore
    Andy
    Downey, CA
    Located in SoCal. $375 shipped sounds like a damn good deal. Will definitely keep that in mind thanks.
  12. Feb 25, 2015 at 1:32 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Yeah, can't handle drone myself. I tried a TRD a few years ago, and wasn't happy with it, IMO sounded ricey at idle and just off idle and it did drone in my cab at about 2200. Above that though, great sound, just didn't spend enough time above 2500 to be worhtwhile. Tried a Magnaflow dropin next, it had a bit of a drone at 2000-2500, so ran that for a while, then had a Borla drop-in welded in place of the Magnaflow. Still has a slight drone, but best of the three.
    Drone is very subjective, one person's drone, doesn't bother anyone else. Also can't hear drone in sound clips. Good luck.
  13. Feb 25, 2015 at 1:44 PM
    Taco89
    Taco89 Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    had a borla on my older truck but decided to pocket $400 of it on my new truck and bought an aero turbine muffler that has an internal resonator. no rasp and i think sounds better than the borla.
  14. Feb 25, 2015 at 2:47 PM
    humbotaco
    humbotaco Active Member
    2015 TRD Off-Road AccessCab
    It is. I paid 510 shipped to CA just a month ago
    I've read somewhere that the TRD is the only exhaust that's been dynotested for a HP increase (7hp iirc). It's also less droney than many other mufflers.
  15. Feb 25, 2015 at 3:10 PM
    1stTruck
    1stTruck Well-Known Member
    Jim
    South Carolina
    PreRunner
    Billies 5100's front set to 1.75 plus 1/4 taco lean spacer. Rears Billies plus AAL for a 2" leaf. 265/75/16 BGF's. Double din Kenwood stereo w/bluetooth and steering wheel controls and JBL speakers front & rear. Heavy duty battery. Billet grill blacked out. K&N air filter and MBRP cat-back. Just tuned it up new plugs and new front brake pads. Steel powered coated tailgate cap. Billet Grill painted black & factory roof racks. Oh new head lights thanks to toyota.
    I am interested in one shipped for that price also.
  16. Feb 25, 2015 at 3:46 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If there was it was probably using an older Gen 2 with the 2.25 stock catback. Also, any HP gains are WAY up high in the range, not useful for daily driving (probably?)
    BTW for others, Toyota started putting 2.5 stock catbacks on instead of 2.25 somewhere around 11-12 model year if I recall correctly.
  17. Feb 25, 2015 at 5:25 PM
    ThomasMore66
    I don't really think it does much unless you add the SC; that's why I have it.
  18. Feb 25, 2015 at 6:41 PM
    TACOBOLTZ619
    TACOBOLTZ619 Active Member
    I'd be interested in one.. 375 is a great deal
