TRD coilover Vs. sr5 coilover
Discussion in 'Suspension' started by MikeyD, Oct 13, 2009.
  1. Oct 13, 2009 at 4:58 PM
    MikeyD
    MikeyD [OP] Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    I have a 4x4 sr5 regular cab and my friend is about to give me his stock TRD Coilovers. Are they better than the coilover that is in my truck now. Should I take them off of his hands and install them in my truck. Any suggestions?
  2. Oct 13, 2009 at 10:29 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Just a guess here....but...
    If you get his TRD coilovers - you'll be getting the OEM bilstein coilover struts.
    What cab truck does he have?
    Does he have an Access cab or double cab and are you getting the coils also? If yes - (and since you have a regular cab) you'll probably get a small lift with his coilovers.
  3. Oct 13, 2009 at 10:33 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yes, the TRD shocks are better than the SR5 ones. When you get the rear TSB AAL done, they replace all the shocks on the truck with TRD billie's to help with the bottoming out issue.
  4. Oct 13, 2009 at 10:34 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    i think they will be the same size...however the coils themselves will be "progressive" which i THINK means they ride a little nicer
  5. Oct 14, 2009 at 3:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Depends on TRD OR or TRD Sport coils. The ORs are progressive, which means they are twisted to provide increasing spring rate under increased load. The Sport coils are not. Progressive tends to ride a bit stiffer if anything.
  6. Oct 14, 2009 at 7:25 AM
    MikeyD
    Sayreville NJ
    Sounds good. So I guess im going to be intalling these soon. And his tacoma was a double cab.
  7. Oct 14, 2009 at 7:27 AM
    Janster
    Jandy
    Lancaster, PA
    If you install the entire coilover assembly (coils & struts)... you're probably gonna get a 1" lift on the front of your regular cab.
    Take measurements before and after. I'm curious to see what you get.
  8. Oct 14, 2009 at 7:29 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    SR5 has nothing to do with the suspension.
  9. Oct 14, 2009 at 7:54 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I agree, although from the factory an SR5 non-TRD in North America does not come with bilstien shocks. Nor would it have the TRD off road coils. I realized he didn't specify SR5 non-TRD, but I think it was pretty clear what he meant.
  10. Oct 14, 2009 at 1:27 PM
    MikeyD
    Sayreville NJ
    Yes i did mean Non- TRD. But this is the question? I have a 3" strut spacer that I was originally going to use for my non- TRD strut. If I use it on his TRD Coilover assembly is it going to lift my truck to much like 4 inches and but too much of a angle on my cv joints?
