TRD Cold Air Intake Dilemma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrZoggs, Jan 16, 2010.
  1. Jan 16, 2010 at 11:40 AM
    MrZoggs
    MrZoggs [OP] Ainokea
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    Okay, So I contacted Toyota to ask them when the 2010 4.0L TRD CAI will become available for my truck.. Well apparently their not going to be available until mid March.. :frusty:
    Obviously I'm not very happy about this.. :mad:
    Anyways.. I started thinking about it and figured I might have a quick and easy solution, but am unsure as to if it'll work on my truck. So getting right to the main point.. :rolleyes:
    Will a 2009 4.0L TRD Cold Air Intake fit my 2010 4.0L Engine? If im not mistaken, or misinformed.. the engine has been left relatively unchanged from 2009 to 2010. From my knowledge I wouldn't anticipate their being any problems installing last years model onto my truck. However, I'm cautious about doing it for a few reasons..
    1) Why would Toyota with drawl a part from production to replace it under a new part code unless it has been altered in some way, shape or form. Which could only be logically explained because Toyota altered something that would require the new part to fit the old engine?
    2) If the 2009 will fit my 2010 Tacoma, will it cause any codes to turn on? I'm primarily worried about the O2 sensors and check engine light coming on...
    3) And will it affect my warranty in any way.. I'm guessing it wont.. but you never know with these guys..
    Has anybody installed a 09 CAI on their 010?? :confused:
    Sorry about the whole speal guys, but I'm pretty adamant about what I'm gona be doing to this truck and am making sure its all done right the first time. :eek:
    Anyways any input would be awesome, I will also be making a call to Toyota on Monday to reassure myself if I decide to go with the previous model intake.
    Thanks
    ~Zoggs
  2. Jan 16, 2010 at 11:43 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I can't imagine them being different, but I really have no idea...
  3. Jan 16, 2010 at 11:54 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    There weren't any engine changes from the 09's to 10's so it should work.
  4. Jan 16, 2010 at 12:14 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Don't get not worth it....Unless your'e gonna be hitten 6000rpms regularly
  5. Jan 16, 2010 at 12:19 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    It's not all about sound. Mine performs very well.
  6. Jan 16, 2010 at 12:20 PM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    i had the same trd intake on a 09 and 2010 it works the exact same.
  7. Jan 16, 2010 at 12:21 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2.
  8. Jan 16, 2010 at 12:27 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    it will work
  9. Jan 16, 2010 at 12:51 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Don't you have to be at full throttle to see any power gains. Unless you race it at the TRACK (for the kidos) the only practical reason it can be used for is passing up slow moveing cars on the high way ($350 to do this). Cause the hp gains aren't through out the power band. just my 2 cents :)
  10. Jan 16, 2010 at 12:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. The one I tested gave a 3 hp gain. HOWEVER, it cleans up the looks of the engine bay, gives you a cleanable reuseable filter, etc. FWIW, I wouldnt run one in a dusty envimonment, as I havent done an oil sample with one installed, I dont expect it to be much better at filtering than a K&N.
  11. Jan 16, 2010 at 4:11 PM
    MrZoggs
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    Well, after very little debate I decided to go ahead and pick up an 09 TRD Cold Air Intake from the dealer.
    Luckily, I was able to obtain an employee discount from a friend of mine and only shelled out $300.00 Flat for it. :p
    Took me about an hour to get it home and install it. Installation was pretty straight forward and didn't require much work. Although i spent more time looking for a 4mm socket than I did putting the thing on my truck..... But all in all I'm pretty satisfied with the ending results. :D
    I can already feel the gains in power and the other benefits that accompany it as well. And am highly anticipating the addition of a URD Sprint Booster Calibration Device + the URD MAF Calibrator. Both of which, (i hope) will make my little truck that much better.
    ~Zoggs
