TRD Cold Air Intake - initial thoughts & review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by torsf_tw, Feb 23, 2017.
  1. Mar 6, 2018 at 1:55 PM
    #61
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Think Helmholtz resonator you see on exhausts. Same principle. Basically eliminates unwanted frequencies.
    Dirty Harry[QUOTED] likes this.
  2. Mar 6, 2018 at 1:56 PM
    #62
    commbubba19
    '23 TRD PRO
    That's not entirely true.
    Tcoma16 likes this.
  3. Mar 6, 2018 at 2:01 PM
    #63
    commbubba19
    '23 TRD PRO
    wut
    anyone expecting 20+ hp increase from an air intake on a NA vehicle is going to be disappointed.
    Also, the computer/sensor do not control temperature. Not sure where you got that from. The ECU simply adjusts timing based on many factors, including air intake temps.
    Engines that gauge timing and fuel from a MAF base the calculation off voltage received from the sensor based on air flow and the calculated circumference of the intake tube that the MAF is located in. Changed the circumference and you will need a tune as you're throwing off the ECU's table of values. So some intakes for other cars (think mustang) include tuner/CAI packages that will see more gains vs an intake only.
    However, any increase in air velocity and volume is usually beneficial to an engine, especially as cool of an air charge as possible.
  4. Mar 6, 2018 at 2:04 PM
    #64
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    bolt ons are usually pretty useless without a tune on most cars.
    taco2010trd likes this.
  5. Mar 6, 2018 at 2:19 PM
    #65
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Thank you. "Helmholtz" has given me some new reading material!
    commbubba19[QUOTED] likes this.
  6. Mar 6, 2018 at 4:21 PM
    #66
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Why didn't they just make the fake scoop real and point the CAI at it instead of the fender...?
    02Duck and Dirty Harry like this.
  7. Mar 6, 2018 at 4:45 PM
    #67
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Because that disrupts the air flow through the grill to the radiator; also ram air intakes on regular cars are worthless.
    TBV[QUOTED] likes this.
  8. Mar 25, 2018 at 6:48 PM
    #68
    Beau_Higgins
    Beau_Higgins Well-Known Member
    FYI for anybody that hasn't read the write up on the other thread... you can buy the $23 'air accelerator' peice from the TRD intake assembly seperate along with an oiled air filter and your stock intake will essentially accomplish the same thing for around $75.
  9. May 1, 2018 at 7:31 PM
    #69
    c4ifford
    c4ifford Active Member
    Gen3 TRD
    none yet
    So I'm curious how it's 2018 and there's still so much hearsay and conjecture around the performance gains of intakes/exhausts. Are there no solid numbers anywhere?
  10. May 1, 2018 at 9:08 PM
    #70
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    I like the TRD intake kit, but not sure about using the oiled filter? would using the dry OEM paper filter defeats the whole purpose of installing the kit? or would you still get some benefits?
    thank you,
  11. May 1, 2018 at 11:46 PM
    #71
    ThinkMud
    ThinkMud Well-Known Member
    2020 4Runner TRD Off Road Premium
    leveling lift, wheel spacers, yakima cross bars for the canoe.
    That's a price I would swing lol Got any part numbers? could also maybe seal the part that goes into the fender better?
  12. May 2, 2018 at 11:21 AM
    #72
    lebvette75
    lebvette75 Well-Known Member
    Larry
    Pine Bluff, Arkansas
    2017 Tacoma TRD Offroad 4x4...Excess Cab...Dark Gray color
    Method 305NV machined face wheels(16") BF Goodrich AT KO2 (stock size) Marathon camo seat covers Skinz tailgate letters AVS window visors
    A true CAI will benefit the engine in one way. It will feed the engine cooler air, which will keep the computer for cutting the timing. If you think you will feel it at the seat of your pants.....you will be disappointed.
    I'm new to the 3rd Gen. Tacoma's, but I'm not knew at performance cars. My air box (2017 OR) seems to be sealed from the engine bay heat. As far as the straighter shot of the box to the engine.....I don't really see a problem. If you were shifting at 7 or 8k you might get a benefit of a straighter line, but I have never made that redline in mine.
    If you actually want some seat of the pants HP, simply invest in a performance tune. By the time you buy all the bolt-ons you would have been able to pay for the tune.
    The size of the paper filter to the size of this engine is adequate. Besides a paper filter will clean better than the oil ones.
    Some of this will change if you are running 12" wrinkle-walls and shifting at 8k, but you can not get real HP with out spending real money, and replacing something that the vehicle already has with something else doesn't always pay with a lot of HP.
    Bolt ons do not impress me much. It's your money, but most the time you will go faster only because your wallet is lighter.
    I have a 640 HP, cammed 08 Z06. I have a CAI because it did not come with one, I have headers, head work, and all the other goodies, because I have a lot of horses to feed, but at 280Hp I wouldn't worry too much about running out of air, or getting the air out.
  13. May 9, 2018 at 6:05 PM
    #73
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Okay so I spent the coin and got one of these TRD CAI. Local dealer had them discounted to $361.60 which sealed the deal for me. Also picked up an OEM bed mat for $81.90 while I was at it.
    Installed this afternoon and it took about 2 hours as I went slow. Nothing really hard about the install except fitting the rubber parts together which took some grunting and groaning and a few choice expletives. No codes and the truck so far is running great. Took it on a 7 mile test drive and I climbed all over it in ECT whenever I had some free road ahead. Mileage for the little test drive was 22.1 despite a bit of heavy throttle. The last tank I filled up this morning before install was 21.8 for the entire tank full which is up from winter driving. Time will tell if there is any real long term MPG gains. As to power, can't really tell in this short run. Sound... I don't hear much difference unless I really climb on the throttle, so no worries about excess noise just doing normal driving. I'm happy with it.
    Stormpeacock, 407guy and tAcomaPueblo like this.
  14. Jul 6, 2018 at 9:33 AM
    #74
    raadkins16
    raadkins16 Member
    2018 Cement TRD Sport
    If you don't mind me asking, what did the dealer charge to install a CAI and exhaust?
  15. Dec 2, 2018 at 12:05 PM
    #75
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    How does the TRD CAI lower the intake air temp? I looked at my stock intake and the intake air comes in from the same left fender as the TRD CAI would.
  16. Dec 2, 2018 at 12:16 PM
    #76
    bigbear1612
    Gary
    I have looked at the factory intake and the air is coming from the same place in the left fender well as the TRD CAI would. I just don't see how the TRD CAI could lower the intake air temp.
  17. Dec 2, 2018 at 12:19 PM
    #77
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    It doesn't.
    hiPSI likes this.
  18. Dec 3, 2018 at 9:11 AM
    #78
    bigbear1612
    Gary
    Your OME intake is a CAI if you look in the air box you will see that the intake air is coming from the right fender well just the same as the TRD CAI is and it came from the factory that way! All you need to do is add a K&N air filter for more air flow.
  19. Dec 20, 2018 at 3:31 PM
    #79
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    2018 MGM Tacoma TRD Sport 4X4 M/T
    TRD Cold Air Intake TRD Manual Transmission Shift Knob Tacoma All-Weather Floor Mats Tacoma Center Console Organizer Tacoma Roof Rack Tacoma Tri-Fold Tonneau Cover TRD Exhaust TRD Pro Fox Shocks (front & rear) TRD Matte Grey 17" Wheels 265/70/17 Falken Wildpeak Tires OV Tune SFOB Premium Tune Accumulator Delete
    If you install the TRD intake yourself, does this void your warranty with Toyota or the dealership?
  20. Dec 20, 2018 at 4:47 PM
    #80
    bigbear1612
    Gary
    I looked at the TRD CAI and decided to just put a K&N filter, only cost me $45.00. If you look at the stock OME CAI that is already on the Taco you will see that the air comes from the same right fender well as the TRD CAI would. So I couldn't see how the TRD CAI could cool the intake air anymore that the stock OME would. I have a scan gauge and it shows the intake air is only about 7 degrees cooler than the outside air. I don't think the TRD CAI would do any better, I guess if you like the look of the TRD CAI on the engine, that's OK but I save my money for something else. I am still considering the TRD cat back exhaust.
