Trd confusion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rangerrzr, Nov 18, 2017.
  1. Nov 18, 2017 at 10:07 AM
    Rangerrzr
    Rangerrzr [OP] New Member
    2005 tacoma
    Sorry if this has been asked lots of times I can't find a definite answer I have a 99 Tacoma trd I also have a 2005 Tacoma sr5 both are auto can I take e locker 3rd member from 99 and put in 2005 Tacoma housing thank you all for any input
  2. Nov 18, 2017 at 10:18 AM
    Pigpen
    Dan
    Northwest Montana
    No
    tcBob likes this.
  3. Nov 18, 2017 at 10:24 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Negative sir!
    tcBob likes this.
  4. Nov 18, 2017 at 12:48 PM
    Rangerrzr
    2005 tacoma
    Thanks guys appreciate it
    Pigpen likes this.
